Run JavaScript if a file is created
25 Posts 3 Posters 13.3k Views 2 Watching
  • E Offline
    EoF
    Might be wise to incorporate some AJAX into this, no? Having PHP check the file, etc and then pass the results / message back to JS.
    • K Offline
      KirAsh4 Moderator
      Not necessarily:
      MM² module --> node_helper --> php --> node_helper --> MM² module
      E 1 Reply Last reply Jul 29, 2016, 1:56 PM Reply Quote 0
      • O Offline
        ooom416354 @KirAsh4
        @KirAsh4 This is awesome!
        I would just put this in my JS file, right? I’m currently sending the following command through Tasker to the Pi so I think I’m good.
        touch curr-train.txt
        • K Offline
          KirAsh4 Moderator
          Earlier you mentioned you using PHP, so I kept it in the loop. Use node_helper to call the PHP script. Let the PHP script check for the file and report back to node_helper which in turn reports to the module.
          O 2 Replies Last reply Jul 28, 2016, 8:32 PM Reply Quote 0
          • O Offline
            ooom416354 @KirAsh4
            @KirAsh4 OK, so my PHP script is actually index.php, it’s effectively the page that loads and is my Mirror. In that file I have a reference to the JS file which runs the mta code.
            <script src="js/mm-mta.js"></script>
            So would I put the following in the PHP page? (sorry if I sound dumb here)
            var prev_datestamp = 0;
            var expire_time = 15 * 60 * 1000; // 15 minutes
            // run every five minutes
            if (file exists) {
              if (file.datestamp > previous_datestamp) {
                previous_datestamp = file.datestamp;
              } else if (now > file.datestamp + expire_time) {
              <script src="https://code.jquery.com/jquery-1.10.2.js"></script>
              <script>
                  $("#mta").empty();
              </script>
            • O Offline
              ooom416354 @KirAsh4
              @KirAsh4 for reference here’s the full index.php file
              index.php
              • K Offline
                KirAsh4 Moderator
                Oy, why do it that way … your index.php will never get updated if there’s an upstream change in the code (because we use index.html). You should use the existing infrastructure in MM². Create a new module, have it display in a specific region on the mirror. Every 5 minutes, have the module refresh by doing a call to its node_helper. The node_helper can be a simply python script that checks the specific file in question and reports back to the module.
                I thought the PHP script was doing something … it’s not in this case. You don’t need PHP at all for this.
                Some places to look for coding ideas:
                MM² Module Development Documentation
                Look at how modules such as the calendar and newsfeed implement a node_helper which does the background tasks
                You could still use PHP to do the file checking for you, but to me that’s a bit of an unnecessary overhead.
                O 2 Replies Last reply Jul 28, 2016, 8:50 PM Reply Quote 0
                • O Offline
                  ooom416354 @KirAsh4
                  @KirAsh4 LOL - I’m just lost these days with all of this stuff. I should stick to my DB work.
                  Let me see what I can do with the module documentation, it would be a good experience anyway to learn.
                  • O Offline
                    ooom416354 @KirAsh4
                    @KirAsh4 Just out of curiosity, if I were to add the code you provided into the PHP file, would i need to bracket it with <?php then add the code here?>
                    • K Offline
                      KirAsh4 Moderator
                      This is hard to answer because I don’t know what your PHP file looks like. I don’t know if you are echo-ing HTML data, or using HEREDOC? I’m flying blind here … (as much fun as that could be)
                      O 1 Reply Last reply Jul 28, 2016, 11:25 PM Reply Quote 0
                      • 2 / 3
                      2 / 3
