    Problem with PIR Sensor not working
    2 Posts 2 Posters 2.9k Views 2 Watching
    • I Offline
      Iron_Reptar
      I just got my mirror up and running and was trying to install the PIR sensor module provided by @paviro (https://github.com/paviro/MMM-PIR-Sensor) but it doesn’t seem to be working. I followed the step by step instructions as written and still the screen does not turn off. I even stuck the sensor (still wired up) under a box and no luck.
      I bought these PIR sensors (http://a.co/aYDzwAS) and am using these to plug in the sensor http://imgur.com/a/VEu0F . They are connected directly to the sensor with jumper wires.
      My modification to the modules config file looks like this.
      module: 'MMM-PIR-Sensor',
          sensorPIN: 22,
          powerSaving: true,
          powerSavingDelay: 0,
          relayOnState: 1
      I also ran the command /opt/vc/bin/tvservice -s and receive the output state 0x120006 [DVI DMT (68) RGB full 16:10], 1920x1200 @ 60.00Hz, progressive
      One thing I did notice is that while running through the install process, I ran sudo chmod u+s /opt/vc/bin/tvservice && sudo chmod u+s /bin/chvt but it said chmod: cannot access 'bin/chvt': No such file or directory
      Anyone able to help?
        malicious_banjo
        Have you confirmed the sensor itself is actually working?
        Write out the following python script and run it:
        import gpizero import MotionSensor
        pir = MotionSensor(x) //x = the out pin on your Pi.
        while True:
             if pir.motion_detected:
                  print("Motion detected!")
             else:
                  print("Nothing")
        And make sure you’re using the BCM pin numbering.
