    MMM-DHT-Sensor - Get temperature & humidity values from a DHT sensor
    22 Posts 9 Posters 18.5k Views 9 Watching
    • Z Offline
      Zoltan
      Hi
      I have the same problem. Sometimes it will start and show correctly and other times it will just show “Loading sensor data”. When it starts It will then update the values for a few times. It then freeze and just wont update again. It doesn’t disappear like it should for 1/3rd of a second to do the update anymore.
      • BKeyportB Offline
        BKeyport Module Developer
        If the author ever comes back, I’ve made a couple of changes to the module that I’d love to see applied.
        Floating point trouble, (both temperature and humidity values are coming up as “xx.xxx9999999999”)
        I have a DHT22, but it did this with the DHT11 too, before I burned it up trying to move it from one board to another.
        This gives you the tens and rounds off the rest.
        // Convert C to F
        			if (this.config.units === "imperial") {
        				this.temperature = Math.round((data.temperature * 9/5 + 32)*10)/10;
        			} else {
        				this.temperature = data.temperature;
        			if (typeof this.temperature !== "undefined" && this.temperature !== null)  {
        				this.sendNotification("INDOOR_TEMPERATURE", this.temperature);
        			this.humidity = Math.round(data.humidity*10)/10;
        			if (typeof this.humidity !== "undefined" && this.humidity !== null)  {
        				this.sendNotification("INDOOR_HUMIDITY", this.humidity);
        			this.updateDom(this.config.animationSpeed);
