    MMM-PIR-SENSOR after updating
    2 Posts 1 Posters 1.6k Views 1 Watching
    • F
      Fonfon
      sorry for this noob question but how i can fix this problem ?
      WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node’
      was compiled against a different Node.js version using
      NODE_MODULE_VERSION 50. This version of Node.js requires
      NODE_MODULE_VERSION 53. Please try re-compiling or re-installing
      the module (for instance, using npm rebuild ornpm install).
      no one have this problem ?
      • F
        Fonfon
        ok i find the solution …
        I have delete the folder MagicMirror/modules/MMM-PIR-Sensor
        git clone
        npm install
        and its ok .
