    System temperature really hot
    11 Posts 6 Posters 9.6k Views 4 Watching
      dmcinnes Module Developer @KirAsh4
      @KirAsh4 How quiet is that fan?
      I’m also having heat problems with a Raspberry Pi 3, gets up to 80C then starts to give the rainbow square in the corner.
      I’ve just tried underclocking and it’s not making any difference:
      arm_freq=900
      arm_freq_min=60
      My load average is hovering at 0.8 with four cores!
      I think I need some more ventilation. When I remove the mirror from the wall it cools down considerably.
      • KirAsh4K Offline
        KirAsh4 Moderator
        My fan is quiet, but remember that these are cheap fans. You may get a very noisy one. Fans are cheap, you can buy a bunch of them and figure out which is the quietest. Or you can find some really quiet ones through an electronics vendor such as DigiKey or Mouser, and pay a higher price for them. I replaced two 30mm square, very noisy fans on my 3D printer, $7 each at the time. Now they’re a little over $9. Good fans are expensive.
        FYI, both my rpis are running at 1GHz.
        • P Offline
          plumcraft
          Thanks for your replies, i’m going to buy a new box for my Pi 3 with a quality fan
            Thanks @KirAsh4 ! I bought a case to try out as well.
            • MichMichM Offline
              MichMich
              Mine is around 65C as well. Stable, for the past few months.
              • MichMichM Offline
                MichMich
                Good to know: mine isn’t actively cooled. It’s not inside a box, but it is inside the Mirror’s casing.
                • KirAsh4K Offline
                  KirAsh4 Moderator
                  With mine, as the temperature started to get higher and higher, the HDMI started dropping out. It would cause the monitor to blank out momentarily. It would stop late in the evening and be fine, but then during the day I would start seeing it again. Boosting the HDMI signal on the rpi didn’t help (in fact it made the temperature go up a bit higher even), but whenever I just blew across the rpi’s CPU, it would stop. That’s how I realized it was just getting too hot, even at the default speed. Now that I put it in a case with a fan, I haven’t had any issues.
