    Trafficmaps
    63 Posts 11 Posters 88.6k Views 12 Watching
      alexyak
      Instead of Google, you could also use Microsoft’s Bing service to get a map with accidents:
      https://msdn.microsoft.com/en-us/library/hh441726
      https://msdn.microsoft.com/en-us/library/hh305205.aspx
      • T Offline
        tyho
        Good one! i will see if i can get something working.
        What i try to do is:
        • Get a map with a route to my work.
        • Get traffic status along this route.
        • Style the maps so it’s nice visable through the mirror. (black/white maps and red lines/triangels for traffic jam.
        • Abillity to switch route with @alexyak voicecontrol module. (work me = to amsterdam) (work girlfriend = to utrecht)
        This are a few wishes. But i am happy already if i get the first two working ^^ i am not skilled at node and js at all… any help is appreciated.
        • T Offline
          tyho
          ok just for the record. if i got the most simple maps js api code:
          <!DOCTYPE html>
          <html>
            <head>
              <title>Simple Map</title>
              <meta name="viewport" content="initial-scale=1.0">
              <meta charset="utf-8">
              <style>
                html, body {
                  height: 100%;
                  margin: 0;
                  padding: 0;
                #map {
                  height: 100%;
              </style>
            </head>
            <body>
              <div id="map"></div>
              <script>
                var map;
                function initMap() {
                  map = new google.maps.Map(document.getElementById('map'), {
                    center: {lat: -34.397, lng: 150.644},
                    zoom: 8
              </script>
              <script src="https://maps.googleapis.com/maps/api/js?key=YOUR_API_KEY&callback=initMap"
              async defer></script>
            </body>
          </html>
          can i just create a module with:
          var x = document.getElementById("map").id;for the div?
          var x = document.createElement("SCRIPT");for the script tags? (w3schools said it supports async and defer)
          and then create 2 functions. 1 for the src api url that i can callback within the script tags and 1 for the initMap that i can callback after the scr url?
          Is this good thinking or is it not that simple?
          • T Offline
            tyho
            i am feeling close but also so far far away ^^ ghehe
            Module.register("trafficmaps",{
            	defaults: {
            	start: function(){
            		Log.info('Starting module: ' + this.name);
            	initMap: function(){
            		var map;
                      zoom: 8
            	getDom: function() {
            		var mapdiv = document.getElementById("map");
            		wrapper.appendChild(mapdiv);
            		var maps = document.createElement('script');
            		maps.type = 'text/javascript'; maps.async = true; maps.defer = true;
            		maps.src="https://maps.googleapis.com/maps/api/js?key=YOUR_API_KEY&callback=" + this.initMap;
            		wrapper.appendChild(maps);
            		return wrapper;
            This script hangs… and it prevents other modules loading…
            • T Offline
              tyho
              I am also trying the bing option seperately but also no result. I’ll keep trying. I am wondering why there arn’t any scripts on the web yet. I think this is for there experts among us ^^
              • T Offline
                tyho
                i found a example of bing maps: https://github.com/jwalgran/bing
                Anyone who can turn this into a module? I already tried but no succes :(
                  alexyak @tyho
                  @tyho so what exactly you’re trying to implement? What would be a use case here for the MM?
                  • T Offline
                    tyho
                    @alexyak What i tried to create is a map view from my home to my work. With on this map the trafficjam/delay. (google can do with the red orange green lines and bing with the triangles). With this map i can see in the morning when i wake up, if i have to leave earlier because of traffic jam. This where my first thoughts for the module. (but with my ms frontpage experience i can’t get this working ^^)
                    As a second thought i had in mind to use your voice module (or facial recgnition module) to switch between my map and that of my girlfriend. So another map is loaded.
                    In the google static map that i already created there is no option to add a traffic layer.
                    In both google maps and bing maps there are style options to make the map black and white for better display. and for example the traffic jam could be red displayed.
                      alexyak @tyho
                      @tyho alright, now I understand your requirements… I can’t promise, but will try to have a look at this over a few coming days.
                      • T Offline
                        tyho
                        @alexyak that would be awesome. I guess there will be much interest for a module like this looking on the topic views ^^
                          alexyak @tyho
                          @tyho
                          Here’s a basic module traffic map module to display a static map with a route and traffic based on bing api’s:
                          'use strict';
                          Module.register('maproute',{
                          	defaults: {
                                  key: "your_bing_map_key",
                                  start: "Morganville, NJ",
                                  end: "New York, NY",
                          	start: function() {
                                  // Override dom generator.
                          		var wrapper = document.createElement("img");
                                          wrapper.style = "position:center; width:600px; height:600px;";
                                          wrapper.src = "http://dev.virtualearth.net/REST/V1/Imagery/Map/Road/Routes?wp.0=" + this.config.start + ";46&wp.1=" + this.config.end + ";46&mapLayer=TrafficFlow&TravelMode=Driving&mapSize=600,600&key=" + this.config.key;
                          		return wrapper;
                          Unfortunately there’s no way to change the style of the map on bing (black and white). You can get your map key from here:
                          https://www.bingmapsportal.com/
                          Thanks… Alex
                          T 1 Reply Last reply Reply Quote 1
                          • T Offline
                            tyho @alexyak
                            @alexyak Thnx for the module! I will try it when i am home :)
                            • W Offline
                              wscheer
                              @tyho @alexyak
                              Wow guys thanks! I was a few steps behind tyho trying to get the google maps traffic option to work. I searched every few weeks for this and finally came upon this thread. I have a traffic map on my magic mirror now!!!
                              For any super beginners (like myself) here are a few notes to add this to my magic mirror page.
                              • Create a dir in your modules dir (ex: MagicMirror/modules/maproute/
                              • Create a file called maproute.js (ex: MagicMirror/modules/maproute/maproute.js) This is where you copy in the code above that alexyak posted
                              • Edit your config.js file to add the module to your page:
                                I don’t think position and config are required but I stuck them in there and it works ok.
                                                    module: 'maproute',
                                                    position: 'top_right',
                                                    config: {}
                              Restart your pi or restart the magic mirror service and you should be all set!
                              If I missed anything or anything is wrong, please let me know
                              The map is cut off in my screenshot but I haven’t changed the sizing or anything yet.
                              S 1 Reply Last reply Reply Quote 2
                                shgmongohh @wscheer
                                @wscheer
                                Thanks for the little tutorial!
                                Could you please explain, with which module do you calculating the current time to your work and mom?
                                Sebastian
                                • strawberry 3.141S Offline
                                  strawberry 3.141 Project Sponsor Module Developer @shgmongohh
                                  @shgmongohh [card:SamLewis0602/MMM-Traffic]
                                  N 1 Reply Last reply Reply Quote 1
                                  • N Offline
                                    Notumlord @strawberry 3.141
                                    @strawberry-3.141 said in Trafficmaps:
                                    Hijacking this thread since i cant find one specific for MMM-Traffic.
                                    I can only get the “driving” mode to work with MMM-Traffic, if i anything else it’s stuck on Loading Commute.
                                    Anyone else have this issue?
                                    strawberry 3.141S M 2 Replies Last reply Reply Quote 0
                                      strawberry 3.141 Project Sponsor Module Developer @Notumlord
                                      @Notumlord if the author is not registered in this forum, then the best way would be to open an issue on github https://github.com/SamLewis0602/MMM-Traffic/issues
                                        Mitchfarino Module Developer @Notumlord
                                        @Notumlord @strawberry-3-141
                                        I have these two working fine for me in my config
                                        		module: 'MMM-Traffic',
                                        		position: 'bottom_right',
                                        		classes: 'dimmed medium', //optional, default is 'bright medium', only applies to commute info not route_name
                                        			api_key: '',
                                        			mode: 'bicycling',
                                        			origin: 'my origin',
                                        			destination: 'my destination',
                                        			route_name: 'Home to Work',
                                        			changeColor: true,
                                        			showGreen: false,
                                        			limitYellow: 5, //Greater than 5% of journey time due to traffic
                                        			limitRed: 20, //Greater than 20% of journey time due to traffic
                                        			traffic_model: 'pessimistic',
                                        			interval: 120000 //2 minutes
                                        			api_key: '',
                                        			mode: 'driving',
                                        			changeColor: true,
                                        			showGreen: false,
                                        • N Offline
                                          Notumlord @Mitchfarino
                                          @Mitchfarino
                                          Strange, do you use the exact same origin/destination for both modules or do you format them differently depending on the mode?
                                            @Notumlord exactly the same origin and destination, using my postcode for home as the origin and postcode for work as the destination
                                            If you want to share your sample config, I can put it in my mirror to see if it works
                                            • 2 / 4
