    Trafficmaps
    63 Posts 11 Posters 89.2k Views 12 Watching
      alexyak @tyho
      @tyho alright, now I understand your requirements… I can’t promise, but will try to have a look at this over a few coming days.
      • T Offline
        tyho
        @alexyak that would be awesome. I guess there will be much interest for a module like this looking on the topic views ^^
          alexyak @tyho
          @tyho
          Here’s a basic module traffic map module to display a static map with a route and traffic based on bing api’s:
          'use strict';
          Module.register('maproute',{
          	defaults: {
                  key: "your_bing_map_key",
                  start: "Morganville, NJ",
                  end: "New York, NY",
          	start: function() {
          		Log.info('Starting module: ' + this.name);
                  // Override dom generator.
          	getDom: function() {
          		var wrapper = document.createElement("img");
                          wrapper.style = "position:center; width:600px; height:600px;";
                          wrapper.src = "http://dev.virtualearth.net/REST/V1/Imagery/Map/Road/Routes?wp.0=" + this.config.start + ";46&wp.1=" + this.config.end + ";46&mapLayer=TrafficFlow&TravelMode=Driving&mapSize=600,600&key=" + this.config.key;
          		return wrapper;
          Unfortunately there’s no way to change the style of the map on bing (black and white). You can get your map key from here:
          https://www.bingmapsportal.com/
          Thanks… Alex
          • T Offline
            tyho @alexyak
            @alexyak Thnx for the module! I will try it when i am home :)
            • W Offline
              wscheer
              @tyho @alexyak
              Wow guys thanks! I was a few steps behind tyho trying to get the google maps traffic option to work. I searched every few weeks for this and finally came upon this thread. I have a traffic map on my magic mirror now!!!
              For any super beginners (like myself) here are a few notes to add this to my magic mirror page.
              • Create a dir in your modules dir (ex: MagicMirror/modules/maproute/
              • Create a file called maproute.js (ex: MagicMirror/modules/maproute/maproute.js) This is where you copy in the code above that alexyak posted
              • Edit your config.js file to add the module to your page:
                I don’t think position and config are required but I stuck them in there and it works ok.
                                    module: 'maproute',
                                    position: 'top_right',
                                    config: {}
              Restart your pi or restart the magic mirror service and you should be all set!
              If I missed anything or anything is wrong, please let me know
              The map is cut off in my screenshot but I haven’t changed the sizing or anything yet.
                shgmongohh @wscheer
                @wscheer
                Thanks for the little tutorial!
                Could you please explain, with which module do you calculating the current time to your work and mom?
                Sebastian
                • strawberry 3.141S Offline
                  strawberry 3.141 Project Sponsor Module Developer @shgmongohh
                  @shgmongohh [card:SamLewis0602/MMM-Traffic]
                  N 1 Reply Last reply Reply Quote 1
                  • N Offline
                    Notumlord @strawberry 3.141
                    @strawberry-3.141 said in Trafficmaps:
                    Hijacking this thread since i cant find one specific for MMM-Traffic.
                    I can only get the “driving” mode to work with MMM-Traffic, if i anything else it’s stuck on Loading Commute.
                    Anyone else have this issue?
                    strawberry 3.141S M 2 Replies Last reply Reply Quote 0
                      strawberry 3.141 Project Sponsor Module Developer @Notumlord
                      @Notumlord if the author is not registered in this forum, then the best way would be to open an issue on github https://github.com/SamLewis0602/MMM-Traffic/issues
                        Mitchfarino Module Developer @Notumlord
                        @Notumlord @strawberry-3-141
                        I have these two working fine for me in my config
                        		module: 'MMM-Traffic',
                        		position: 'bottom_right',
                        		classes: 'dimmed medium', //optional, default is 'bright medium', only applies to commute info not route_name
                        			api_key: '',
                        			mode: 'bicycling',
                        			origin: 'my origin',
                        			destination: 'my destination',
                        			route_name: 'Home to Work',
                        			changeColor: true,
                        			showGreen: false,
                        			limitYellow: 5, //Greater than 5% of journey time due to traffic
                        			limitRed: 20, //Greater than 20% of journey time due to traffic
                        			traffic_model: 'pessimistic',
                        			interval: 120000 //2 minutes
                        			api_key: '',
                        			mode: 'driving',
                        			changeColor: true,
                        			showGreen: false,
                        • N Offline
                          Notumlord @Mitchfarino
                          @Mitchfarino
                          Strange, do you use the exact same origin/destination for both modules or do you format them differently depending on the mode?
                            @Notumlord exactly the same origin and destination, using my postcode for home as the origin and postcode for work as the destination
                            If you want to share your sample config, I can put it in my mirror to see if it works
                            • W Offline
                              wscheer
                              Hey All,
                              I’ve been tinkering around with the Bing Traffic maps a little more. I made it a bit more customizable but I’m having an issue where the map never refreshes.
                              I’ve tried calling updateDom() but that does not seem to do anything. I also tried setting the wrapper to ’ ’ before it is set to the bing url path.
                              Any ideas?
                              Module.register("maproute", {
                                      defaults: {
                                              latitude: '40.4406', // city latitude
                                              longitude: '-79.9959', // city longitude
                                              map_zoom: '12', // 1 - 21
                                              map_layer: 'TrafficFlow',
                                              map_size: '500', // using this for both length and width
                                              api_key: '1234567890', //  your bing maps api key
                                              updateInterval: 300000 // 5 mins
                                              var wrapper = ''; // tried setting this to blank to see if that would clear out the old image
                                              // create the url using the custom parameters
                                              wrapper.src = "http://dev.virtualearth.net/REST/v1/Imagery/Map/Road/" + this.config.latitude + "," + this.config.longitude + "/" + this.config.map_zoom + "?mapSize=" + this.config.map_size + "," + this.config.map_size + "&ml=" + this.config.map_layer + "&key=" + this.config.map_key;
                                              return wrapper;
                              	start: function() {
                              		var self = this;
                              		setInterval(function() {
                              			self.updateDom(); // no speed defined, so it updates instantly.
                              		}, this.config.updateInterval);
                                strawberry 3.141 Project Sponsor Module Developer @wscheer
                                @wscheer Quote from the readme Whenever your module need to be updated, call the updateDom(speed) method. It requests the MagicMirror core to update it's dom object. If you define the speed, the content update will be animated, but only if the content will realy change. So i guess your html looks all the time the same, so there is probably no real update of the dom. I suggest to try to add an timestamp somewhere and see if it gets updated then
                                • W Offline
                                  wscheer
                                  @strawberry-3-141 Ding! Ding! Ding! That was it! THANK YOU!
                                  Also thanks again to @alexyak and @tyho for their input.
                                  I’ll post the code for anyone who wants Bing Traffic maps on their Magic Mirror.
                                  It’s a little hackish but maybe someone will come along and write it the correct way. Basically I’m taking the pushpin (pp) parameter and just assigning two random numbers to it. Math.random() creates a number between 0 and 1. So the map never shows the pushpin on the area I’m at. This causes the information to be “new” so when updateDom() is called, the info has changed.
                                  For any beginners, here is my file structure setup:
                                  The code below is located: /var/www/html/MagicMirror/modules/maproute/maproute.js
                                          defaults: {
                                                  latitude: '40.4406', // City latitude. Use google to get these coordinates
                                                  longitude: '-79.9959', // City longitude
                                                  map_size: '500', // Using this for both length and width
                                                  api_key: '123456789', // Your Bing maps api key
                                                  updateInterval: 300000 // 5 min refresh
                                                  var wrapper = '';
                                                  // The Math.random() calls are to place a random pushpin on the map and make the updateDom() call refresh
                                                  wrapper.src = "http://dev.virtualearth.net/REST/v1/Imagery/Map/Road/" + this.config.latitude + "," + this.config.longitude + "/" + this.config.map_zoom + "?mapSize=" + this.config.map_size + "," + this.config.map_size + "&pp=" + Math.random() + "," + Math.random() + "&ml=" + this.config.map_layer + "&key=" + this.config.map_key;
                                                  return wrapper;
                                  	start: function() {
                                  		var self = this;
                                  			self.updateDom(5000); // I set a 5 second refresh here for testing.
                                  J Z 2 Replies Last reply Reply Quote 1
                                    Jeff @wscheer
                                    @wscheer
                                    Is this modul still working?
                                    I did everthing you explained:
                                    in my config.js:
                                                          module: 'maproute',
                                                          position: 'middle_center',
                                    And /var/www/html/MagicMirror/modules/maproute/maproute.js is the code from above.
                                    I’ve created an API for Bing maps.
                                    But if I run MM I just see a small image. Like the right picture could not be found.
                                    And if I look to the report om bing how often my API was used, it counts 0.
                                    Where is the mistake?
                                    • W Offline
                                      wscheer @Jeff
                                      @Jeff yeah mine is still working.
                                      To troubleshoot you could run magic mirror in “standalone” mode. That would let you view the page on a desktop computer and you can look at the browser console to see what the errors are.
                                      Let me know if you need more instructions on that. I’m on a mobile right now. I could add more later.
                                        Jeff @wscheer
                                        @wscheer
                                        Thanks for your quick reply.
                                        Can you just tell me how to enter the “standalone” mode?
                                        thanks
                                        • W Offline
                                          wscheer @Jeff
                                          @Jeff yeah
                                          execute the following command from the MagicMirror folder: “node serveronly”. This will start the server, after which you can open the application in your browser of choice.
                                            Jeff @wscheer
                                            @wscheer
                                            oh okay, I already did that and the command line said my page was created correctly.
                                            But in teh browser it said page not found.
                                            I think that’s a different problem and I have to handle that first…
                                            • 2 / 4
