    Newsfeed "ignoreOldItems" does not work
    3 Posts 2 Posters 2.3k Views 3 Watching
      StrikeBack83
      my config says to ignore items older than 14 hours (50400000ms),
      but that does not work. I still see news older than this.
      Heres my newsfeed module:
                module: "newsfeed",
                position: "bottom_bar",
                showSourceTitle: true,
                showPublishDate: true,
                         feeds: [
                                 title: "Kurier",
                                 url: "http://kurier.at/xml/rssd"
                                 title: "Der Standard",
                                 url: "http://derStandard.at/?page=rss&ressort=Seite1"
                                 title: "Giga",
                                 url: "http://www.giga.de/feed/"
                         ignoreOldItems: "true",
                         ignoreOlderThan: 50400000,
                         updateInterval: 20000
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @StrikeBack83
        @StrikeBack83 I just checked your config and it seems to work fine, as the oldest news I got was 12.5 hours old.
        Though there are some small issues with your config:
            feeds: [
        showSourceTitle and showPublishDate are config options and have to be moved into the config section like
            feeds: [
        But why did they work then? Because their default value is set to true so you don’t have to specify it at all like
            feeds: [
        Another issue is ignoreOldItems. A boolean (true and false) have to be defined without quotes, otherwise it will be always true. "true" => true and "false" => true
          ignoreOldItems: true,
          StrikeBack83
          If
          is true by default i’m going to delete it completely.
          I’ll try the “ignoreOldItems: true” without quote marks when i get home!
          Thanks!
          Edit: Seems like it’s working at the moment. Obviously it was the “true” in quots.
