Newsfeed "ignoreOldItems" does not work
3 Posts 2 Posters 2.2k Views 3 Watching
    StrikeBack83
    my config says to ignore items older than 14 hours (50400000ms),
    but that does not work. I still see news older than this.
    Heres my newsfeed module:
              module: "newsfeed",
              position: "bottom_bar",
              showSourceTitle: true,
              showPublishDate: true,
                       feeds: [
                               title: "Kurier",
                               url: "http://kurier.at/xml/rssd"
                               title: "Der Standard",
                               url: "http://derStandard.at/?page=rss&ressort=Seite1"
                               title: "Giga",
                               url: "http://www.giga.de/feed/"
                       ignoreOldItems: "true",
                       ignoreOlderThan: 50400000,
                       updateInterval: 20000
    S 1 Reply Last reply Jul 28, 2017, 10:16 AM Reply Quote 0
      strawberry 3.141 Project Sponsor Module Developer @StrikeBack83
      @StrikeBack83 I just checked your config and it seems to work fine, as the oldest news I got was 12.5 hours old.
      Though there are some small issues with your config:
          feeds: [
      showSourceTitle and showPublishDate are config options and have to be moved into the config section like
          feeds: [
      But why did they work then? Because their default value is set to true so you don’t have to specify it at all like
          feeds: [
      Another issue is ignoreOldItems. A boolean (true and false) have to be defined without quotes, otherwise it will be always true. "true" => true and "false" => true
        ignoreOldItems: true,
        StrikeBack83
        If
        is true by default i’m going to delete it completely.
        I’ll try the “ignoreOldItems: true” without quote marks when i get home!
        Thanks!
        Edit: Seems like it’s working at the moment. Obviously it was the “true” in quots.
