    Show webpage / iframe and reload
    14 Posts 4 Posters 11.6k Views 4 Watching
    • U Offline
      usafa43tsolo @strawberry 3.141
      @strawberry-3.141 That did it. Loads perfectly now. Thank you for pointing that out!
      • foxF Offline
        fox
        @strawberry-3-141 you mean that fix?
        adding the line:
        iframe.setAttribute("timestamp", new Date().getTime());
        this results in:
        getDom: function() {
                        var iframe = document.createElement("IFRAME");
                        iframe.style = "border:0"
                        iframe.width = this.config.width;
                        iframe.height = this.config.height;
                        iframe.src =  this.config.url + new Date().getTime();
                        return iframe;
        but no result
        @usafa43tsolo could you share your .js file please?
        edit:
        i reinstalled it and then put the fix from @strawberry-3-141 from github.
        now i see in my browser (in the respective frame)
        Cannot GET /www.google.com
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @fox
          @fox did you try another webpage? I think it’s possible for a webpage to deny rendering in an iframe
          EDIT: See, when I’m testing this in a simple html file < iframe src="https://www.google.com">< /iframe> (without the spaces)
          I get this error Refused to display 'https://www.google.com/' in a frame because it set 'X-Frame-Options' to 'SAMEORIGIN'.
          • foxF Offline
            fox
            @strawberry-3-141
            i saw something similar.
            But with your hint of deny i created a .htaccess in the folder of the called page with content
            Options -Indexes
            and now i can see the page !
            Thank you for your hint now we can proceed here.
