    Show webpage / iframe and reload
    14 Posts 4 Posters 12.7k Views 4 Watching
      barnosch
      i had the same and i could fix it, in my special case, by simply reloading the webpage periodically i want to show.
      (i use a wepage that crawls the status of my automatic lawn mower and shows me informations like status and battery)
      If you handle the webpage yourself, thats an easy option.
      If you want to show a external source, it’s not working.
      • strawberry 3.141S
        @fox @usafa43tsolo which modules did you try, there are several of them
        U 1 Reply Last reply
        • U
          usafa43tsolo @strawberry 3.141
          @strawberry-3.141 I used this module, which I found from the wiki: https://github.com/alberttwong/MMM-iFrame
          • strawberry 3.141S
            strawberry 3.141 Project Sponsor Module Developer @usafa43tsolo
            @usafa43tsolo you could give this one a try https://github.com/TheBogueRat/MMM-iFrameReload
            https://github.com/desertblade/iFrame
            • U
              usafa43tsolo
              Those are the two I’ve tried, specifically the first one. There was a thread that fox referenced that had the same issue and was supposedly fixed but I installed it correctly and fixed (I think) the config file. However, nothing ever shows up.
              • strawberry 3.141S
                @usafa43tsolo which one of those 4?
                • U
                  usafa43tsolo
                  https://forum.magicmirror.builders/topic/2637/mmm-iframereload-iframe-won-t-load/7
                  • strawberry 3.141S
                    @usafa43tsolo did you try to apply this fix i suggested here a few months ago? https://github.com/TheBogueRat/MMM-iFrameReload/issues/2#issuecomment-291011351
                    • U
                      @strawberry-3.141 That did it. Loads perfectly now. Thank you for pointing that out!
                      • F
                        fox
                        @strawberry-3-141 you mean that fix?
                        adding the line:
                        iframe.setAttribute("timestamp", new Date().getTime());
                        this results in:
                        getDom: function() {
                                        var iframe = document.createElement("IFRAME");
                                        iframe.style = "border:0"
                                        iframe.width = this.config.width;
                                        iframe.height = this.config.height;
                                        iframe.src =  this.config.url + new Date().getTime();
                                        return iframe;
                        but no result
                        @usafa43tsolo could you share your .js file please?
                        edit:
                        i reinstalled it and then put the fix from @strawberry-3-141 from github.
                        now i see in my browser (in the respective frame)
                        Cannot GET /www.google.com
                        Issues With MMM-WatchDog known?
                        https://forum.magicmirror.builders/post/29827
                        Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                        • strawberry 3.141S
                          strawberry 3.141 Project Sponsor Module Developer @fox
                          @fox did you try another webpage? I think it’s possible for a webpage to deny rendering in an iframe
                          EDIT: See, when I’m testing this in a simple html file < iframe src="https://www.google.com">< /iframe> (without the spaces)
                          I get this error Refused to display 'https://www.google.com/' in a frame because it set 'X-Frame-Options' to 'SAMEORIGIN'.
                          • F
                            fox
                            @strawberry-3-141
                            i saw something similar.
                            But with your hint of deny i created a .htaccess in the folder of the called page with content
                            Options -Indexes
                            and now i can see the page !
                            Thank you for your hint now we can proceed here.
