    Thin Monitor Solution
    10 Posts 3 Posters 7.1k Views 3 Watching
      A Former User
      I’m looking to make a shallow-depth mirror and I was wondering if there was a better solution than using a tiny, recycled laptop monitor + LCD controller board. Shopping for regular monitors, it’s tough to know what the total depth of the guts that I’ll need (once the plastic is ripped off). Can anyone recommend a super thin-traditional LCD monitor?
        A Former User @Guest
        @mizzoudavis
        My 17inch lcd(LP173WF3) has 0.4cm. Normal lcd monitor is usually thicker than that, I guess.
          sero
          I used an Asus MB169B+
          https://www.asus.com/de/Monitors/MB169BPlus/
            @Sean Thanks. Did you need an LCD controller board as well?
            ? 2 Replies Last reply Reply Quote 0
              A Former User @sero
              @sero Interesting solution. Does it take USB only as an input? Any issues there?
                @mizzoudavis small palm sized board is needed. You can purchase in amazon, ebay or other replacement shop.
                  sero @Guest
                  @mizzoudavis
                  I removed the controller (which has just USB) and replaced it with a controller from eBay that has HDMI, VGA, etc.:
                  eBay item 360626141655 :)
                    @mizzoudavis
                    https://www.amazon.de/Display-LP173WD1-LTN173KT01-LTN173KT02-B173RW01/dp/B00AOMQPWG/ref=sr_1_1?ie=UTF8&qid=1502388884&sr=8-1&keywords=Lp173wd1
                    https://www.amazon.de/Eingang-Controller-LP173WD1-B173RW01-1600-x-900-40pins-LCD-Bildschirm/dp/B06W5DTGKC/ref=sr_1_2?s=computers&ie=UTF8&qid=1502388955&sr=1-2&keywords=Lp173wd1+controller
                    I live in Germany. So i link these in amazon.de however you can find these in any country.
                      @Sean Thank you! I wonder if the USB output of the controller board is enough to power the RPi?
                        @mizzoudavis enough but sometimes not stable. I use another hub.
