    Asus Tinker Board
    27 Posts 8 Posters 23.5k Views 9 Watching
    • ? Offline
      A Former User
      Is there anyone who has an experience with Asus Tinker Board?
      I’ve got one today and am waiting for new SD card arrival.
      My old one was RPi 3 model B, It worked perfectly, but I’ve felt something insufficient. So I ordered an ATB on Amazon.
      Here is a brief comparison
      Raspberry Pi 3 Model B vs. Asus Tinker Board
      35 - 40 EUR Price in Germany
      (Amazon.de)
      55 - 60 EUR
      9 x 6 x 1 cm Dimension 9 x 6 x 1 cm
      (perfectly same with RPI 3 Model B)
      Cortex-A53 Quad-core 1.2GHz Processor Cortex-A17 Quad-core 1.8GHz
      1GB LPDDR2 Memory 2GB LPDDR3
      HDMI, supports HD resolution Display Output HDMI supports H.264 4K resolution
      MicroSD Storage MicroSD (UHS-I Support)
      up to 48K/16bit sample rate Audio up to 192k/24bit sample rate
      Bluetooth 4.1 Classic Low Energy,
      10/100 Ethernet,
      2.4GHz 802.11n
      Connectivity Bluetooth 4.0 + EDR,
      Gigabit Ethernet ,
      802.11n
      Micro-USB Power Micro-USB
      Linux-Debian OS Support Linux-Debian
      I have not checked all compatibility issues of Tinkerboard yet. I just hope there would not be any problem. :)
      Currently, I consider playing videos on my mirror, that’s why I need stronger. I hope this might be the one as I thought.
      • cowboysdudeC Offline
        cowboysdude Module Developer
        No experience with it but it looks like it may be able to handle more than the Pi! Let us know!
        • ? Offline
          A Former User
          Today, I got a new SD card So I tried.
          OS installation was not difficult as I’ve heard. OS is TinkerOS_Debian V2.0.1 (Beta version). I used Etcher for making image on SD with ease. Etcher is a really great tool!
          TinkerOS has already lxde and some useful pieces of stuff.(like Fonts, etc) Someone said TinkerOS is not so good as Raspbian. For me, however, It’s pretty enough.
          I’ve done some processes necessary like apt-get upgrade, install git, install node…
          After then I tried to install MagicMirror by auto-install scripts in MM sites. I made mm.sh for auto-start and reboot.
          There was no problem.
          It worked without any problem. I’ve installed some modules for test, they worked also well.
          Performance is really nice.
          Of course, MM doesn’t need so much computing power. But when I opened Chromium browser in Desktop mode, Wow. the performance was almost same with normal PC. (Yup, That’s what I’ve felt.) Moving window was very smooth! Page loading was so fast!
          I know the real performance of PC class is very different with these Single-board computers, But I’m satisfied with this new toy. I confirm there is worthy of 20 EUR(the price gap with RPi3B)
          strawberry 3.141S SnilleS 2 Replies Last reply Reply Quote 2
          • strawberry 3.141S Offline
            strawberry 3.141 Project Sponsor Module Developer @Guest
            @Sean would be interesting to see the performance of cpu intensive tasks like offline voice recognition and face recognition and so on
            ? 1 Reply Last reply Reply Quote 1
            • ? Offline
              A Former User @strawberry 3.141
              @strawberry-3.141 Yes, I’ll try something like those. After that I’ll write here.
              • SnilleS Offline
                Snille Module Developer
                Just got mine as well. :)
                Here you can find the OS (and other stuff), if someone else is looking.
                Tinker Board Software
                  I believe that as MM grows it is out growing the RPI. Hate to say it but at this point it really is… So this new board may be the answer for a few things!
                  • SnilleS Offline
                    Mmmm… I’m thinking MinnowBoard Turbot… Maybe? :)
                    • SnilleS Offline
                      Snille Module Developer @Guest
                      @Sean what did you put in your mm.sh?
                      I can’t get the MM to run… I only get errors… :/ I’m on development branch…
                      got this in the npm-debug.log:
                      cat npm-debug.log
                      1 verbose cli [ '/usr/bin/nodejs', '/usr/bin/npm', 'start' ]
                      2 info using npm@3.10.10
                      3 info using node@v6.11.2
                      5 info lifecycle magicmirror@2.1.3-dev~prestart: magicmirror@2.1.3-dev
                      6 silly lifecycle magicmirror@2.1.3-dev~prestart: no script for prestart, continuing
                      7 info lifecycle magicmirror@2.1.3-dev~start: magicmirror@2.1.3-dev
                      8 verbose lifecycle magicmirror@2.1.3-dev~start: unsafe-perm in lifecycle true
                      9 verbose lifecycle magicmirror@2.1.3-dev~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/snille/MagicMirror/node_modules/.bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
                      10 verbose lifecycle magicmirror@2.1.3-dev~start: CWD: /home/snille/MagicMirror
                      11 silly lifecycle magicmirror@2.1.3-dev~start: Args: [ '-c', 'sh run-start.sh' ]
                      12 silly lifecycle magicmirror@2.1.3-dev~start: Returned: code: 1  signal: null
                      13 info lifecycle magicmirror@2.1.3-dev~start: Failed to exec start script
                      14 verbose stack Error: magicmirror@2.1.3-dev start: `sh run-start.sh`
                      14 verbose stack Exit status 1
                      14 verbose stack     at EventEmitter. (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
                      14 verbose stack     at emitTwo (events.js:106:13)
                      14 verbose stack     at EventEmitter.emit (events.js:191:7)
                      14 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
                      14 verbose stack     at ChildProcess.emit (events.js:191:7)
                      14 verbose stack     at maybeClose (internal/child_process.js:891:16)
                      14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
                      15 verbose pkgid magicmirror@2.1.3-dev
                      16 verbose cwd /home/snille/MagicMirror
                      17 error Linux 4.4.71+
                      18 error argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                      19 error node v6.11.2
                      20 error npm  v3.10.10
                      21 error code ELIFECYCLE
                      22 error magicmirror@2.1.3-dev start: `sh run-start.sh`
                      22 error Exit status 1
                      23 error Failed at the magicmirror@2.1.3-dev start script 'sh run-start.sh'.
                      23 error Make sure you have the latest version of node.js and npm installed.
                      23 error If you do, this is most likely a problem with the magicmirror package,
                      23 error not with npm itself.
                      23 error Tell the author that this fails on your system:
                      23 error     sh run-start.sh
                      23 error You can get information on how to open an issue for this project with:
                      23 error     npm bugs magicmirror
                      23 error Or if that isn't available, you can get their info via:
                      23 error     npm owner ls magicmirror
                      23 error There is likely additional logging output above.
                      24 verbose exit [ 1, true ]
                      ? Cr4z33C 2 Replies Last reply Reply Quote 0
                      • ? Offline
                        A Former User @Snille
                        @Snille mine has no problem. In ‘mm.sh’ only npm start is.
                        • SnilleS Offline
                          Oh, when I tried it with the default “linaro” user it works… :) I used “my own” user at first… Now I’m going to add modules! :)
                          • SnilleS Offline
                            This post is deleted!
                            • SnilleS Offline
                              Ah, just figured out how to rotate the screen. When logged in as “linaro”.
                              Open a terminal and do:
                              cd ~
                              nano .xsessionrc
                              Paste the following in the file and remove the # in front of the row (left or right) you want to rotate the screen. I am using left myself. :)
                              #!/bin/sh
                              ## To rotate left enable below line.
                              xrandr --output HDMI-1 --rotate left
                              ## To rotate right enable below line.
                              #xrandr --output HDMI-1 --rotate right
                              Reboot to test. :)
                              • SnilleS Offline
                                All the same modules installed and here is the “nmon” result…
                                To the left is the “Tinker Board” and to the right is the “Raspberry Pi 3”. :)
                                And here is the module list:
                                MMM-Chart
                                MMM-Globe
                                MMM-JSONStatusChecker
                                MMM-Memo
                                MMM-ModuleScheduler
                                MMM-Modulebar
                                MMM-MotionEye
                                MMM-MyCommute
                                MMM-ProfileSwitcher
                                MMM-Profilepicture
                                MMM-Remote-Control
                                MMM-Sonos
                                MMM-SystemStats
                                MMM-TextClock
                                MMM-TouchNavigation
                                MMM-WunderGround
                                MMM-cryptocurrency
                                MMM-newsfeedtouch
                                MMM-plex-recently-added
                                calendar_monthly
                                mm-hide-all
                                mmm-suncalc
                                ? 2 Replies Last reply Reply Quote 1
                                • ? Offline
                                  @Snille impressive!
                                  • ? Offline
                                    @Snille MMM-SystemStat should be modified for CPU temperature. ATB write cpu temp on different location.
                                    SnilleS 1 Reply Last reply Reply Quote 0
                                    • SnilleS Offline
                                      @Sean Yes, I noticed. I actually disabled the MMM-SystemStats module for now. It’s complaining too much in the log. :)
                                      • SnilleS Offline
                                        Hi again. Tried another OS called Armbian. I like the “looks” better to start with. So if you are going to use you Tinker Board for something else then being a MM. Maybe it’s a nicer alternative then TinkerOS. But for MM, it’s not. The over all CPU usage is even higher then on the RPi3… Tough, it seems to be X that’s hogging most of the CPU… It’s running XFCE instead of LXDE so, maybe that’s the reason…
                                        If you want to play with even more OS:es you can find lot’s here.
                                        • ? Offline
                                          @Snille Have you find tvservice equivalent? I cannot find how to turn on/off display programmatically on TB.
                                          Will tvservice building work?
                                            ranger33
                                            could use a hand as there doesn’t seem to be much support in the community which is odd!
                                            Got one today, loaded a fresh sd card with a fresh install of their newest os and i can’t get it to boot! It swirls around and around for a while loading different things but eventually just crashing:/ Anyone else have this issue? Power supply?
