    Asus Tinker Board
    27 Posts 8 Posters 22.4k Views 9 Watching
    • cowboysdudeC Offline
      No experience with it but it looks like it may be able to handle more than the Pi! Let us know!
        A Former User
        Today, I got a new SD card So I tried.
        OS installation was not difficult as I’ve heard. OS is TinkerOS_Debian V2.0.1 (Beta version). I used Etcher for making image on SD with ease. Etcher is a really great tool!
        TinkerOS has already lxde and some useful pieces of stuff.(like Fonts, etc) Someone said TinkerOS is not so good as Raspbian. For me, however, It’s pretty enough.
        I’ve done some processes necessary like apt-get upgrade, install git, install node…
        After then I tried to install MagicMirror by auto-install scripts in MM sites. I made mm.sh for auto-start and reboot.
        There was no problem.
        It worked without any problem. I’ve installed some modules for test, they worked also well.
        Performance is really nice.
        Of course, MM doesn’t need so much computing power. But when I opened Chromium browser in Desktop mode, Wow. the performance was almost same with normal PC. (Yup, That’s what I’ve felt.) Moving window was very smooth! Page loading was so fast!
        I know the real performance of PC class is very different with these Single-board computers, But I’m satisfied with this new toy. I confirm there is worthy of 20 EUR(the price gap with RPi3B)
        strawberry 3.141S SnilleS 2 Replies Last reply Reply Quote 2
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @Guest
          @Sean would be interesting to see the performance of cpu intensive tasks like offline voice recognition and face recognition and so on
          ? 1 Reply Last reply Reply Quote 1
            A Former User @strawberry 3.141
            @strawberry-3.141 Yes, I’ll try something like those. After that I’ll write here.
            • SnilleS Offline
              Snille Module Developer
              Just got mine as well. :)
              Here you can find the OS (and other stuff), if someone else is looking.
              Tinker Board Software
              If you cant find it, make it and share it!
              Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
                I believe that as MM grows it is out growing the RPI. Hate to say it but at this point it really is… So this new board may be the answer for a few things!
                • SnilleS Offline
                  Mmmm… I’m thinking MinnowBoard Turbot… Maybe? :)
                  • SnilleS Offline
                    Snille Module Developer @Guest
                    @Sean what did you put in your mm.sh?
                    I can’t get the MM to run… I only get errors… :/ I’m on development branch…
                    got this in the npm-debug.log:
                    cat npm-debug.log
                    1 verbose cli [ '/usr/bin/nodejs', '/usr/bin/npm', 'start' ]
                    2 info using npm@3.10.10
                    3 info using node@v6.11.2
                    5 info lifecycle magicmirror@2.1.3-dev~prestart: magicmirror@2.1.3-dev
                    6 silly lifecycle magicmirror@2.1.3-dev~prestart: no script for prestart, continuing
                    7 info lifecycle magicmirror@2.1.3-dev~start: magicmirror@2.1.3-dev
                    8 verbose lifecycle magicmirror@2.1.3-dev~start: unsafe-perm in lifecycle true
                    9 verbose lifecycle magicmirror@2.1.3-dev~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/snille/MagicMirror/node_modules/.bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
                    10 verbose lifecycle magicmirror@2.1.3-dev~start: CWD: /home/snille/MagicMirror
                    11 silly lifecycle magicmirror@2.1.3-dev~start: Args: [ '-c', 'sh run-start.sh' ]
                    12 silly lifecycle magicmirror@2.1.3-dev~start: Returned: code: 1  signal: null
                    13 info lifecycle magicmirror@2.1.3-dev~start: Failed to exec start script
                    14 verbose stack Error: magicmirror@2.1.3-dev start: `sh run-start.sh`
                    14 verbose stack Exit status 1
                    14 verbose stack     at EventEmitter. (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
                    14 verbose stack     at emitTwo (events.js:106:13)
                    14 verbose stack     at EventEmitter.emit (events.js:191:7)
                    14 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
                    14 verbose stack     at ChildProcess.emit (events.js:191:7)
                    14 verbose stack     at maybeClose (internal/child_process.js:891:16)
                    14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
                    15 verbose pkgid magicmirror@2.1.3-dev
                    16 verbose cwd /home/snille/MagicMirror
                    17 error Linux 4.4.71+
                    18 error argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                    19 error node v6.11.2
                    20 error npm  v3.10.10
                    21 error code ELIFECYCLE
                    22 error magicmirror@2.1.3-dev start: `sh run-start.sh`
                    22 error Exit status 1
                    23 error Failed at the magicmirror@2.1.3-dev start script 'sh run-start.sh'.
                    23 error Make sure you have the latest version of node.js and npm installed.
                    23 error If you do, this is most likely a problem with the magicmirror package,
                    23 error not with npm itself.
                    23 error Tell the author that this fails on your system:
                    23 error     sh run-start.sh
                    23 error You can get information on how to open an issue for this project with:
                    23 error     npm bugs magicmirror
                    23 error Or if that isn't available, you can get their info via:
                    23 error     npm owner ls magicmirror
                    23 error There is likely additional logging output above.
                    24 verbose exit [ 1, true ]
                    ? Cr4z33C 2 Replies Last reply Reply Quote 0
                      A Former User @Snille
                      @Snille mine has no problem. In ‘mm.sh’ only npm start is.
                      • SnilleS Offline
                        Oh, when I tried it with the default “linaro” user it works… :) I used “my own” user at first… Now I’m going to add modules! :)
