    Asus Tinker Board
    27 Posts 8 Posters 23.8k Views 9 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @Guest
      @Sean would be interesting to see the performance of cpu intensive tasks like offline voice recognition and face recognition and so on
      ? 1 Reply Last reply
        A Former User @strawberry 3.141
        @strawberry-3.141 Yes, I’ll try something like those. After that I’ll write here.
        • SnilleS
          Snille Module Developer
          Just got mine as well. :)
          Here you can find the OS (and other stuff), if someone else is looking.
          Tinker Board Software
          • cowboysdudeC
            I believe that as MM grows it is out growing the RPI. Hate to say it but at this point it really is… So this new board may be the answer for a few things!
            • SnilleS
              Mmmm… I’m thinking MinnowBoard Turbot… Maybe? :)
              • SnilleS
                Snille Module Developer @Guest
                @Sean what did you put in your mm.sh?
                I can’t get the MM to run… I only get errors… :/ I’m on development branch…
                got this in the npm-debug.log:
                cat npm-debug.log
                1 verbose cli [ '/usr/bin/nodejs', '/usr/bin/npm', 'start' ]
                2 info using npm@3.10.10
                3 info using node@v6.11.2
                5 info lifecycle magicmirror@2.1.3-dev~prestart: magicmirror@2.1.3-dev
                6 silly lifecycle magicmirror@2.1.3-dev~prestart: no script for prestart, continuing
                7 info lifecycle magicmirror@2.1.3-dev~start: magicmirror@2.1.3-dev
                8 verbose lifecycle magicmirror@2.1.3-dev~start: unsafe-perm in lifecycle true
                9 verbose lifecycle magicmirror@2.1.3-dev~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/snille/MagicMirror/node_modules/.bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
                10 verbose lifecycle magicmirror@2.1.3-dev~start: CWD: /home/snille/MagicMirror
                11 silly lifecycle magicmirror@2.1.3-dev~start: Args: [ '-c', 'sh run-start.sh' ]
                12 silly lifecycle magicmirror@2.1.3-dev~start: Returned: code: 1  signal: null
                13 info lifecycle magicmirror@2.1.3-dev~start: Failed to exec start script
                14 verbose stack Error: magicmirror@2.1.3-dev start: `sh run-start.sh`
                14 verbose stack Exit status 1
                14 verbose stack     at EventEmitter. (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
                14 verbose stack     at emitTwo (events.js:106:13)
                14 verbose stack     at EventEmitter.emit (events.js:191:7)
                14 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
                14 verbose stack     at ChildProcess.emit (events.js:191:7)
                14 verbose stack     at maybeClose (internal/child_process.js:891:16)
                14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
                15 verbose pkgid magicmirror@2.1.3-dev
                16 verbose cwd /home/snille/MagicMirror
                17 error Linux 4.4.71+
                18 error argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                19 error node v6.11.2
                20 error npm  v3.10.10
                21 error code ELIFECYCLE
                22 error magicmirror@2.1.3-dev start: `sh run-start.sh`
                22 error Exit status 1
                23 error Failed at the magicmirror@2.1.3-dev start script 'sh run-start.sh'.
                23 error Make sure you have the latest version of node.js and npm installed.
                23 error If you do, this is most likely a problem with the magicmirror package,
                23 error not with npm itself.
                23 error Tell the author that this fails on your system:
                23 error     sh run-start.sh
                23 error You can get information on how to open an issue for this project with:
                23 error     npm bugs magicmirror
                23 error Or if that isn't available, you can get their info via:
                23 error     npm owner ls magicmirror
                23 error There is likely additional logging output above.
                24 verbose exit [ 1, true ]
                ? Cr4z33C 2 Replies Last reply
                  A Former User @Snille
                  @Snille mine has no problem. In ‘mm.sh’ only npm start is.
                  • SnilleS
                    Oh, when I tried it with the default “linaro” user it works… :) I used “my own” user at first… Now I’m going to add modules! :)
                    • SnilleS
                      • SnilleS
                        Ah, just figured out how to rotate the screen. When logged in as “linaro”.
                        Open a terminal and do:
                        cd ~
                        nano .xsessionrc
                        Paste the following in the file and remove the # in front of the row (left or right) you want to rotate the screen. I am using left myself. :)
                        #!/bin/sh
                        ## To rotate left enable below line.
                        xrandr --output HDMI-1 --rotate left
                        ## To rotate right enable below line.
                        #xrandr --output HDMI-1 --rotate right
                        Reboot to test. :)
                        • SnilleS
                          All the same modules installed and here is the “nmon” result…
                          To the left is the “Tinker Board” and to the right is the “Raspberry Pi 3”. :)
                          And here is the module list:
                          MMM-Chart
                          MMM-Globe
                          MMM-JSONStatusChecker
                          MMM-Memo
                          MMM-ModuleScheduler
                          MMM-Modulebar
                          MMM-MotionEye
                          MMM-MyCommute
                          MMM-ProfileSwitcher
                          MMM-Profilepicture
                          MMM-Remote-Control
                          MMM-Sonos
                          MMM-SystemStats
                          MMM-TextClock
                          MMM-TouchNavigation
                          MMM-WunderGround
                          MMM-cryptocurrency
                          MMM-newsfeedtouch
                          MMM-plex-recently-added
                          calendar_monthly
                          mm-hide-all
                          mmm-suncalc
                          ? 2 Replies Last reply
                            @Snille impressive!
                              @Snille MMM-SystemStat should be modified for CPU temperature. ATB write cpu temp on different location.
                              SnilleS 1 Reply Last reply
                              • SnilleS
                                @Sean Yes, I noticed. I actually disabled the MMM-SystemStats module for now. It’s complaining too much in the log. :)
                                • SnilleS
                                  Hi again. Tried another OS called Armbian. I like the “looks” better to start with. So if you are going to use you Tinker Board for something else then being a MM. Maybe it’s a nicer alternative then TinkerOS. But for MM, it’s not. The over all CPU usage is even higher then on the RPi3… Tough, it seems to be X that’s hogging most of the CPU… It’s running XFCE instead of LXDE so, maybe that’s the reason…
                                  If you want to play with even more OS:es you can find lot’s here.
                                    @Snille Have you find tvservice equivalent? I cannot find how to turn on/off display programmatically on TB.
                                    Will tvservice building work?
                                      ranger33
                                      could use a hand as there doesn’t seem to be much support in the community which is odd!
                                      Got one today, loaded a fresh sd card with a fresh install of their newest os and i can’t get it to boot! It swirls around and around for a while loading different things but eventually just crashing:/ Anyone else have this issue? Power supply?
                                        A Former User @ranger33
                                        @ranger33 maybe. Over 2.5A is recommended.
                                        • SnilleS
                                          @Sean Oh, I missed your comment. I have not clue. :) Have not yet tested the turn off stuff. :)
                                            @Snille I currently use xset. it works well.
