    Asus Tinker Board
    27 Posts 8 Posters 23.6k Views 9 Watching
    • SnilleS Offline
      Snille Module Developer
      Just got mine as well. :)
      Here you can find the OS (and other stuff), if someone else is looking.
      Tinker Board Software
      • cowboysdudeC Offline
        I believe that as MM grows it is out growing the RPI. Hate to say it but at this point it really is… So this new board may be the answer for a few things!
        • SnilleS Offline
          Mmmm… I’m thinking MinnowBoard Turbot… Maybe? :)
          • SnilleS Offline
            Snille Module Developer @Guest
            @Sean what did you put in your mm.sh?
            I can’t get the MM to run… I only get errors… :/ I’m on development branch…
            got this in the npm-debug.log:
            cat npm-debug.log
            1 verbose cli [ '/usr/bin/nodejs', '/usr/bin/npm', 'start' ]
            2 info using npm@3.10.10
            3 info using node@v6.11.2
            5 info lifecycle magicmirror@2.1.3-dev~prestart: magicmirror@2.1.3-dev
            6 silly lifecycle magicmirror@2.1.3-dev~prestart: no script for prestart, continuing
            7 info lifecycle magicmirror@2.1.3-dev~start: magicmirror@2.1.3-dev
            8 verbose lifecycle magicmirror@2.1.3-dev~start: unsafe-perm in lifecycle true
            9 verbose lifecycle magicmirror@2.1.3-dev~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/snille/MagicMirror/node_modules/.bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
            10 verbose lifecycle magicmirror@2.1.3-dev~start: CWD: /home/snille/MagicMirror
            11 silly lifecycle magicmirror@2.1.3-dev~start: Args: [ '-c', 'sh run-start.sh' ]
            12 silly lifecycle magicmirror@2.1.3-dev~start: Returned: code: 1  signal: null
            13 info lifecycle magicmirror@2.1.3-dev~start: Failed to exec start script
            14 verbose stack Error: magicmirror@2.1.3-dev start: `sh run-start.sh`
            14 verbose stack Exit status 1
            14 verbose stack     at EventEmitter. (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
            14 verbose stack     at emitTwo (events.js:106:13)
            14 verbose stack     at EventEmitter.emit (events.js:191:7)
            14 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
            14 verbose stack     at ChildProcess.emit (events.js:191:7)
            14 verbose stack     at maybeClose (internal/child_process.js:891:16)
            14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
            15 verbose pkgid magicmirror@2.1.3-dev
            16 verbose cwd /home/snille/MagicMirror
            17 error Linux 4.4.71+
            18 error argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
            19 error node v6.11.2
            20 error npm  v3.10.10
            21 error code ELIFECYCLE
            22 error magicmirror@2.1.3-dev start: `sh run-start.sh`
            22 error Exit status 1
            23 error Failed at the magicmirror@2.1.3-dev start script 'sh run-start.sh'.
            23 error Make sure you have the latest version of node.js and npm installed.
            23 error If you do, this is most likely a problem with the magicmirror package,
            23 error not with npm itself.
            23 error Tell the author that this fails on your system:
            23 error     sh run-start.sh
            23 error You can get information on how to open an issue for this project with:
            23 error     npm bugs magicmirror
            23 error Or if that isn't available, you can get their info via:
            23 error     npm owner ls magicmirror
            23 error There is likely additional logging output above.
            24 verbose exit [ 1, true ]
            ? Cr4z33C 2 Replies Last reply Reply Quote 0
              A Former User @Snille
              @Snille mine has no problem. In ‘mm.sh’ only npm start is.
              • SnilleS Offline
                Oh, when I tried it with the default “linaro” user it works… :) I used “my own” user at first… Now I’m going to add modules! :)
                • SnilleS Offline
                  • SnilleS Offline
                    Ah, just figured out how to rotate the screen. When logged in as “linaro”.
                    Open a terminal and do:
                    cd ~
                    nano .xsessionrc
                    Paste the following in the file and remove the # in front of the row (left or right) you want to rotate the screen. I am using left myself. :)
                    #!/bin/sh
                    ## To rotate left enable below line.
                    xrandr --output HDMI-1 --rotate left
                    ## To rotate right enable below line.
                    #xrandr --output HDMI-1 --rotate right
                    Reboot to test. :)
                    • SnilleS Offline
                      All the same modules installed and here is the “nmon” result…
                      To the left is the “Tinker Board” and to the right is the “Raspberry Pi 3”. :)
                      And here is the module list:
                      MMM-Chart
                      MMM-Globe
                      MMM-JSONStatusChecker
                      MMM-Memo
                      MMM-ModuleScheduler
                      MMM-Modulebar
                      MMM-MotionEye
                      MMM-MyCommute
                      MMM-ProfileSwitcher
                      MMM-Profilepicture
                      MMM-Remote-Control
                      MMM-Sonos
                      MMM-SystemStats
                      MMM-TextClock
                      MMM-TouchNavigation
                      MMM-WunderGround
                      MMM-cryptocurrency
                      MMM-newsfeedtouch
                      MMM-plex-recently-added
                      calendar_monthly
                      mm-hide-all
                      mmm-suncalc
                      ? 2 Replies Last reply Reply Quote 1
                        @Snille impressive!
                          @Snille MMM-SystemStat should be modified for CPU temperature. ATB write cpu temp on different location.
                          SnilleS 1 Reply Last reply Reply Quote 0
                          • SnilleS Offline
                            @Sean Yes, I noticed. I actually disabled the MMM-SystemStats module for now. It’s complaining too much in the log. :)
                            • SnilleS Offline
                              Hi again. Tried another OS called Armbian. I like the “looks” better to start with. So if you are going to use you Tinker Board for something else then being a MM. Maybe it’s a nicer alternative then TinkerOS. But for MM, it’s not. The over all CPU usage is even higher then on the RPi3… Tough, it seems to be X that’s hogging most of the CPU… It’s running XFCE instead of LXDE so, maybe that’s the reason…
                              If you want to play with even more OS:es you can find lot’s here.
                                @Snille Have you find tvservice equivalent? I cannot find how to turn on/off display programmatically on TB.
                                Will tvservice building work?
                                  ranger33
                                  could use a hand as there doesn’t seem to be much support in the community which is odd!
                                  Got one today, loaded a fresh sd card with a fresh install of their newest os and i can’t get it to boot! It swirls around and around for a while loading different things but eventually just crashing:/ Anyone else have this issue? Power supply?
                                    A Former User @ranger33
                                    @ranger33 maybe. Over 2.5A is recommended.
                                    • SnilleS Offline
                                      @Sean Oh, I missed your comment. I have not clue. :) Have not yet tested the turn off stuff. :)
                                        @Snille I currently use xset. it works well.
                                          jasondreher
                                          Sean, how do you use xset for turning the display on and off? I have set up my tinker board and all works great but the display. I tried to set up a crontab scheduled job with python script but I cannot get it to work. I have a script with “xset dpms force off” in it and it works through cmd window, but I cannot get it to work on a schedule.
                                            A Former User @jasondreher
                                            @jasondreher
                                            Well, I didn’t try like that, but I think it is related to your python script. How about using shell script for xset dpms force off?
