    Asus Tinker Board
    27 Posts 8 Posters 23.5k Views 9 Watching
      [[global:former-user]] @Snille
      @Snille MMM-SystemStat should be modified for CPU temperature. ATB write cpu temp on different location.
      SnilleS 1 Reply Last reply Reply Quote 0
      • SnilleS Offline
        Snille Module Developer @Guest
        @Sean Yes, I noticed. I actually disabled the MMM-SystemStats module for now. It’s complaining too much in the log. :)
        • SnilleS Offline
          Hi again. Tried another OS called Armbian. I like the “looks” better to start with. So if you are going to use you Tinker Board for something else then being a MM. Maybe it’s a nicer alternative then TinkerOS. But for MM, it’s not. The over all CPU usage is even higher then on the RPi3… Tough, it seems to be X that’s hogging most of the CPU… It’s running XFCE instead of LXDE so, maybe that’s the reason…
          If you want to play with even more OS:es you can find lot’s here.
            @Snille Have you find tvservice equivalent? I cannot find how to turn on/off display programmatically on TB.
            Will tvservice building work?
              ranger33
              could use a hand as there doesn’t seem to be much support in the community which is odd!
              Got one today, loaded a fresh sd card with a fresh install of their newest os and i can’t get it to boot! It swirls around and around for a while loading different things but eventually just crashing:/ Anyone else have this issue? Power supply?
                [[global:former-user]] @ranger33
                @ranger33 maybe. Over 2.5A is recommended.
                • SnilleS Offline
                  @Sean Oh, I missed your comment. I have not clue. :) Have not yet tested the turn off stuff. :)
                    @Snille I currently use xset. it works well.
                      jasondreher
                      Sean, how do you use xset for turning the display on and off? I have set up my tinker board and all works great but the display. I tried to set up a crontab scheduled job with python script but I cannot get it to work. I have a script with “xset dpms force off” in it and it works through cmd window, but I cannot get it to work on a schedule.
                        [[global:former-user]] @jasondreher
                        @jasondreher
                        Well, I didn’t try like that, but I think it is related to your python script. How about using shell script for xset dpms force off?
                        • Y Offline
                          yep_DD
                          have you guys also experienced problems with OpenGL? I used the standard MagicMirror install script and did not compile it from scratch:
                          everything works just fine, but ht pm2_error.log shows this and I assume performance could be increased by solving that
                          libGL error: MESA-LOADER: failed to retrieve device information
                          libGL error: unable to load driver: rockchip_dri.so
                          libGL error: driver pointer missing
                          libGL error: failed to load driver: rockchip
                          • Cr4z33C Offline
                            Cr4z33 @Snille
