    Asus Tinker Board
    27 Posts 8 Posters 23.8k Views 9 Watching
    • cowboysdudeC
      No experience with it but it looks like it may be able to handle more than the Pi! Let us know!
        A Former User
        Today, I got a new SD card So I tried.
        OS installation was not difficult as I’ve heard. OS is TinkerOS_Debian V2.0.1 (Beta version). I used Etcher for making image on SD with ease. Etcher is a really great tool!
        TinkerOS has already lxde and some useful pieces of stuff.(like Fonts, etc) Someone said TinkerOS is not so good as Raspbian. For me, however, It’s pretty enough.
        I’ve done some processes necessary like apt-get upgrade, install git, install node…
        After then I tried to install MagicMirror by auto-install scripts in MM sites. I made mm.sh for auto-start and reboot.
        There was no problem.
        It worked without any problem. I’ve installed some modules for test, they worked also well.
        Performance is really nice.
        Of course, MM doesn’t need so much computing power. But when I opened Chromium browser in Desktop mode, Wow. the performance was almost same with normal PC. (Yup, That’s what I’ve felt.) Moving window was very smooth! Page loading was so fast!
        I know the real performance of PC class is very different with these Single-board computers, But I’m satisfied with this new toy. I confirm there is worthy of 20 EUR(the price gap with RPi3B)
        strawberry 3.141S SnilleS 2 Replies Last reply
        Reply Quote 2
        • strawberry 3.141S
          strawberry 3.141 Project Sponsor Module Developer @Guest
          @Sean would be interesting to see the performance of cpu intensive tasks like offline voice recognition and face recognition and so on
          ? 1 Reply Last reply
            A Former User @strawberry 3.141
            @strawberry-3.141 Yes, I’ll try something like those. After that I’ll write here.
            • SnilleS
              Snille Module Developer
              Just got mine as well. :)
              Here you can find the OS (and other stuff), if someone else is looking.
              Tinker Board Software
              • cowboysdudeC
                I believe that as MM grows it is out growing the RPI. Hate to say it but at this point it really is… So this new board may be the answer for a few things!
                • SnilleS
                  Mmmm… I’m thinking MinnowBoard Turbot… Maybe? :)
                  • SnilleS
                    Snille Module Developer @Guest
                    @Sean what did you put in your mm.sh?
                    I can’t get the MM to run… I only get errors… :/ I’m on development branch…
                    got this in the npm-debug.log:
                    cat npm-debug.log
                    1 verbose cli [ '/usr/bin/nodejs', '/usr/bin/npm', 'start' ]
                    2 info using npm@3.10.10
                    3 info using node@v6.11.2
                    5 info lifecycle magicmirror@2.1.3-dev~prestart: magicmirror@2.1.3-dev
                    6 silly lifecycle magicmirror@2.1.3-dev~prestart: no script for prestart, continuing
                    7 info lifecycle magicmirror@2.1.3-dev~start: magicmirror@2.1.3-dev
                    8 verbose lifecycle magicmirror@2.1.3-dev~start: unsafe-perm in lifecycle true
                    9 verbose lifecycle magicmirror@2.1.3-dev~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/snille/MagicMirror/node_modules/.bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
                    10 verbose lifecycle magicmirror@2.1.3-dev~start: CWD: /home/snille/MagicMirror
                    11 silly lifecycle magicmirror@2.1.3-dev~start: Args: [ '-c', 'sh run-start.sh' ]
                    12 silly lifecycle magicmirror@2.1.3-dev~start: Returned: code: 1  signal: null
                    13 info lifecycle magicmirror@2.1.3-dev~start: Failed to exec start script
                    14 verbose stack Error: magicmirror@2.1.3-dev start: `sh run-start.sh`
                    14 verbose stack Exit status 1
                    14 verbose stack     at EventEmitter. (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
                    14 verbose stack     at emitTwo (events.js:106:13)
                    14 verbose stack     at EventEmitter.emit (events.js:191:7)
                    14 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
                    14 verbose stack     at ChildProcess.emit (events.js:191:7)
                    14 verbose stack     at maybeClose (internal/child_process.js:891:16)
                    14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
                    15 verbose pkgid magicmirror@2.1.3-dev
                    16 verbose cwd /home/snille/MagicMirror
                    17 error Linux 4.4.71+
                    18 error argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                    19 error node v6.11.2
                    20 error npm  v3.10.10
                    21 error code ELIFECYCLE
                    22 error magicmirror@2.1.3-dev start: `sh run-start.sh`
                    22 error Exit status 1
                    23 error Failed at the magicmirror@2.1.3-dev start script 'sh run-start.sh'.
                    23 error Make sure you have the latest version of node.js and npm installed.
                    23 error If you do, this is most likely a problem with the magicmirror package,
                    23 error not with npm itself.
                    23 error Tell the author that this fails on your system:
                    23 error     sh run-start.sh
                    23 error You can get information on how to open an issue for this project with:
                    23 error     npm bugs magicmirror
                    23 error Or if that isn't available, you can get their info via:
                    23 error     npm owner ls magicmirror
                    23 error There is likely additional logging output above.
                    24 verbose exit [ 1, true ]
                    ? Cr4z33C 2 Replies Last reply
                      A Former User @Snille
                      @Snille mine has no problem. In ‘mm.sh’ only npm start is.
                      • SnilleS
                        Oh, when I tried it with the default “linaro” user it works… :) I used “my own” user at first… Now I’m going to add modules! :)
                        • SnilleS
                          • SnilleS
                            Ah, just figured out how to rotate the screen. When logged in as “linaro”.
                            Open a terminal and do:
                            cd ~
                            nano .xsessionrc
                            Paste the following in the file and remove the # in front of the row (left or right) you want to rotate the screen. I am using left myself. :)
                            #!/bin/sh
                            ## To rotate left enable below line.
                            xrandr --output HDMI-1 --rotate left
                            ## To rotate right enable below line.
                            #xrandr --output HDMI-1 --rotate right
                            Reboot to test. :)
                            • SnilleS
                              All the same modules installed and here is the “nmon” result…
                              To the left is the “Tinker Board” and to the right is the “Raspberry Pi 3”. :)
                              And here is the module list:
                              MMM-Chart
                              MMM-Globe
                              MMM-JSONStatusChecker
                              MMM-Memo
                              MMM-ModuleScheduler
                              MMM-Modulebar
                              MMM-MotionEye
                              MMM-MyCommute
                              MMM-ProfileSwitcher
                              MMM-Profilepicture
                              MMM-Remote-Control
                              MMM-Sonos
                              MMM-SystemStats
                              MMM-TextClock
                              MMM-TouchNavigation
                              MMM-WunderGround
                              MMM-cryptocurrency
                              MMM-newsfeedtouch
                              MMM-plex-recently-added
                              calendar_monthly
                              mm-hide-all
                              mmm-suncalc
                              ? 2 Replies Last reply
                                @Snille impressive!
                                  @Snille MMM-SystemStat should be modified for CPU temperature. ATB write cpu temp on different location.
                                  SnilleS 1 Reply Last reply
                                  • SnilleS
                                    @Sean Yes, I noticed. I actually disabled the MMM-SystemStats module for now. It’s complaining too much in the log. :)
                                    • SnilleS
                                      Hi again. Tried another OS called Armbian. I like the “looks” better to start with. So if you are going to use you Tinker Board for something else then being a MM. Maybe it’s a nicer alternative then TinkerOS. But for MM, it’s not. The over all CPU usage is even higher then on the RPi3… Tough, it seems to be X that’s hogging most of the CPU… It’s running XFCE instead of LXDE so, maybe that’s the reason…
                                      If you want to play with even more OS:es you can find lot’s here.
                                        @Snille Have you find tvservice equivalent? I cannot find how to turn on/off display programmatically on TB.
                                        Will tvservice building work?
                                          ranger33
                                          could use a hand as there doesn’t seem to be much support in the community which is odd!
                                          Got one today, loaded a fresh sd card with a fresh install of their newest os and i can’t get it to boot! It swirls around and around for a while loading different things but eventually just crashing:/ Anyone else have this issue? Power supply?
                                            A Former User @ranger33
                                            @ranger33 maybe. Over 2.5A is recommended.
