    Asus Tinker Board
    27 Posts 8 Posters 23.8k Views 9 Watching
    • SnilleS
      Snille Module Developer
      Mmmm… I’m thinking MinnowBoard Turbot… Maybe? :)
      • SnilleS
        Snille Module Developer @Guest
        @Sean what did you put in your mm.sh?
        I can’t get the MM to run… I only get errors… :/ I’m on development branch…
        got this in the npm-debug.log:
        cat npm-debug.log
        1 verbose cli [ '/usr/bin/nodejs', '/usr/bin/npm', 'start' ]
        2 info using npm@3.10.10
        3 info using node@v6.11.2
        5 info lifecycle magicmirror@2.1.3-dev~prestart: magicmirror@2.1.3-dev
        6 silly lifecycle magicmirror@2.1.3-dev~prestart: no script for prestart, continuing
        7 info lifecycle magicmirror@2.1.3-dev~start: magicmirror@2.1.3-dev
        8 verbose lifecycle magicmirror@2.1.3-dev~start: unsafe-perm in lifecycle true
        9 verbose lifecycle magicmirror@2.1.3-dev~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/snille/MagicMirror/node_modules/.bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
        10 verbose lifecycle magicmirror@2.1.3-dev~start: CWD: /home/snille/MagicMirror
        11 silly lifecycle magicmirror@2.1.3-dev~start: Args: [ '-c', 'sh run-start.sh' ]
        12 silly lifecycle magicmirror@2.1.3-dev~start: Returned: code: 1  signal: null
        13 info lifecycle magicmirror@2.1.3-dev~start: Failed to exec start script
        14 verbose stack Error: magicmirror@2.1.3-dev start: `sh run-start.sh`
        14 verbose stack Exit status 1
        14 verbose stack     at EventEmitter. (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
        14 verbose stack     at emitTwo (events.js:106:13)
        14 verbose stack     at EventEmitter.emit (events.js:191:7)
        14 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
        14 verbose stack     at ChildProcess.emit (events.js:191:7)
        14 verbose stack     at maybeClose (internal/child_process.js:891:16)
        14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
        15 verbose pkgid magicmirror@2.1.3-dev
        16 verbose cwd /home/snille/MagicMirror
        17 error Linux 4.4.71+
        18 error argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
        19 error node v6.11.2
        20 error npm  v3.10.10
        21 error code ELIFECYCLE
        22 error magicmirror@2.1.3-dev start: `sh run-start.sh`
        22 error Exit status 1
        23 error Failed at the magicmirror@2.1.3-dev start script 'sh run-start.sh'.
        23 error Make sure you have the latest version of node.js and npm installed.
        23 error If you do, this is most likely a problem with the magicmirror package,
        23 error not with npm itself.
        23 error Tell the author that this fails on your system:
        23 error     sh run-start.sh
        23 error You can get information on how to open an issue for this project with:
        23 error     npm bugs magicmirror
        23 error Or if that isn't available, you can get their info via:
        23 error     npm owner ls magicmirror
        23 error There is likely additional logging output above.
        24 verbose exit [ 1, true ]
        ? Cr4z33C 2 Replies Last reply
          A Former User @Snille
          @Snille mine has no problem. In ‘mm.sh’ only npm start is.
          • SnilleS
            Oh, when I tried it with the default “linaro” user it works… :) I used “my own” user at first… Now I’m going to add modules! :)
            • SnilleS
              • SnilleS
                Ah, just figured out how to rotate the screen. When logged in as “linaro”.
                Open a terminal and do:
                cd ~
                nano .xsessionrc
                Paste the following in the file and remove the # in front of the row (left or right) you want to rotate the screen. I am using left myself. :)
                #!/bin/sh
                ## To rotate left enable below line.
                xrandr --output HDMI-1 --rotate left
                ## To rotate right enable below line.
                #xrandr --output HDMI-1 --rotate right
                Reboot to test. :)
                • SnilleS
                  All the same modules installed and here is the “nmon” result…
                  To the left is the “Tinker Board” and to the right is the “Raspberry Pi 3”. :)
                  And here is the module list:
                  MMM-Chart
                  MMM-Globe
                  MMM-JSONStatusChecker
                  MMM-Memo
                  MMM-ModuleScheduler
                  MMM-Modulebar
                  MMM-MotionEye
                  MMM-MyCommute
                  MMM-ProfileSwitcher
                  MMM-Profilepicture
                  MMM-Remote-Control
                  MMM-Sonos
                  MMM-SystemStats
                  MMM-TextClock
                  MMM-TouchNavigation
                  MMM-WunderGround
                  MMM-cryptocurrency
                  MMM-newsfeedtouch
                  MMM-plex-recently-added
                  calendar_monthly
                  mm-hide-all
                  mmm-suncalc
                  ? 2 Replies Last reply
                    @Snille impressive!
                      @Snille MMM-SystemStat should be modified for CPU temperature. ATB write cpu temp on different location.
                      SnilleS 1 Reply Last reply
                      • SnilleS
                        @Sean Yes, I noticed. I actually disabled the MMM-SystemStats module for now. It’s complaining too much in the log. :)
                        • SnilleS
                          Hi again. Tried another OS called Armbian. I like the “looks” better to start with. So if you are going to use you Tinker Board for something else then being a MM. Maybe it’s a nicer alternative then TinkerOS. But for MM, it’s not. The over all CPU usage is even higher then on the RPi3… Tough, it seems to be X that’s hogging most of the CPU… It’s running XFCE instead of LXDE so, maybe that’s the reason…
                          If you want to play with even more OS:es you can find lot’s here.
                          ? 1 Reply Last reply
                            @Snille Have you find tvservice equivalent? I cannot find how to turn on/off display programmatically on TB.
                            Will tvservice building work?
                              ranger33
                              could use a hand as there doesn’t seem to be much support in the community which is odd!
                              Got one today, loaded a fresh sd card with a fresh install of their newest os and i can’t get it to boot! It swirls around and around for a while loading different things but eventually just crashing:/ Anyone else have this issue? Power supply?
                                A Former User @ranger33
                                @ranger33 maybe. Over 2.5A is recommended.
                                • SnilleS
                                  @Sean Oh, I missed your comment. I have not clue. :) Have not yet tested the turn off stuff. :)
                                    @Snille I currently use xset. it works well.
                                      jasondreher
                                      Sean, how do you use xset for turning the display on and off? I have set up my tinker board and all works great but the display. I tried to set up a crontab scheduled job with python script but I cannot get it to work. I have a script with “xset dpms force off” in it and it works through cmd window, but I cannot get it to work on a schedule.
                                        A Former User @jasondreher
                                        @jasondreher
                                        Well, I didn’t try like that, but I think it is related to your python script. How about using shell script for xset dpms force off?
                                        • Y
                                          yep_DD
                                          have you guys also experienced problems with OpenGL? I used the standard MagicMirror install script and did not compile it from scratch:
                                          everything works just fine, but ht pm2_error.log shows this and I assume performance could be increased by solving that
                                          libGL error: MESA-LOADER: failed to retrieve device information
                                          libGL error: unable to load driver: rockchip_dri.so
                                          libGL error: driver pointer missing
                                          libGL error: failed to load driver: rockchip
                                          • Cr4z33C
                                            Cr4z33 @Snille
