    Except a module in getModules()
    14 Posts 3 Posters 6.7k Views 3 Watching
    • Y Offline
      yours.mukul
      var i,modules = MM.getModules().exceptModule(helloworld);
      The above code throws error, while the below doesn’t work
      var i,modules = MM.getModules().exceptModule(‘helloworld’);
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @yours.mukul
        @yours.mukul can you give some context, like the whole module code or what you ate tryng to achieve?
        • Y Offline
          yours.mukul
          I have a button module, which throws notification when a button is pressed. What I want is, it blacks out the whole screen except “Hello World”. So I will be using
          **var i,modules = MM.getModule();
          for(i=0;i
            @yours.mukul exceptModule doens’t work with strings, instead it needs a module instance. What error do you get? The example is from the developers guide
            MM.getModules().exceptModule(helloworld).enumerate(function(module) {
              module.hide(1000, function() {
                //Module hidden.
            Y 2 Replies Last reply Reply Quote 0
            • Y Offline
              yours.mukul @strawberry 3.141
              This post is deleted!
              • Y Offline
                @strawberry-3.141
                                var i,modules =  MM.getModules();
                    		if (notification === "BUTTON_PRESSED"){
                			this.sendNotification(notification, payload);
                                        for(i=0; imodules.length; i+=1){
                                               if(modules[i].hidden == true){
                                                   modules[i].show(0);
                                               else if(modules[i].hidden == false)
                                                     modules[i].hide(0);
                I want to show/hide all the modules except the **hello world ** module. Please help me out with that.
                Note: I was unable to write less than sign in the for loop while writing this reply, I think its a bug, in this forum, whenever I write less than, all the text after it is is ignored.
                  @yours.mukul i can’t test it right now. what error do you get?
                  try the example from the docs
                          //Module hidden.
                  • Y Offline
                    @strawberry-3.141 how to iterate over the modules array ?
                    I want to show/hide all modules except the “helloworld”.
                    ? strawberry 3.141S 2 Replies Last reply Reply Quote 0
                    • ? Offline
                      A Former User @yours.mukul
                      @yours.mukul
                      MM.getModules().enumerate((module)=>{
                        if(module.name !== "helloworld") {
                          module.hide()
                      This is written by hand, so there might be error, but you can understand how it goes.
                        @yours.mukul enumerate will iterate over the array and will execute the function you specify for each module in the array
                        • Y Offline
                          @strawberry-3.141 Well your code didn’t hide any of modules
                          strawberry 3.141S ? 2 Replies Last reply Reply Quote 0
                            @yours.mukul do you get any errors?
                            • ? Offline
                              @yours.mukul
                              In .exceptModule(someModule), someModule should be an instance of module object. It means you should get the object first before enumerating.
                              Usually, you can get module object instance with notification. In other way, you should enumerate all modules first, filter them by name(or any other condition), after then you can use those objects for .exceptModule() as parameter.
                              So I think you’d better examine other modules how they handle this. Not so difficult.
                              • Y Offline
                                @strawberry-3.141 No there were no errors but I didn’t hide my modules
