    Question regarding mirror and monitor bezel.
    13 Posts 2 Posters 8.1k Views 2 Watching
      j.e.f.f Project Sponsor Module Developer @EventHorizon
      @EventHorizon said in Question regarding mirror and monitor bezel.:
      Yeah it’s sitting right on the glass.
      Does this mean your TV has a glass in front of the screen, then you are putting the glass mirror over top? I think you’re seeing reflection as the result of the glass-on-glass situation. I think you may have this problem no matter what mirror you put in front of it. In which case, the acrylic might be the better choice for you, as the back side won’t reflect as much light back at the TV.
      • E Offline
        EventHorizon @j.e.f.f
        @j.e.f.f Apologies, I may have confused you. The monitor does NOT have glass in front of the screen, only the two samples that I placed directly on top of the monitor. So I’m not really sure why the reflection is present. So just to confirm there is no glass on glass. So i’m not really sure why the reflection is present. Any ideas Jeff?
          @EventHorizon I’d try a sample from another manufacturer to see if the problem goes away.
