    IP White List
    7 Posts 3 Posters 4.9k Views 3 Watching
    • Y Offline
      yours.mukul
      How to allow my MagicMirror to be internet accessible?
      I’m using duckdns and port forwarding, I need any ip to access my MagicMirror. How to do it?
      • P Offline
        psteimann
        I do it with teamviewer, much better than VNC because it transmits the alt-key which you need to minimize the window of MM to do the settings…no dns or portforwarding needed…
        • P Offline
          psteimann
          it works with any dyndns also, if portforwarding-settings and firewall-settings are correct and i think jaca has to be enabled in the Browser, not shure. Check your port in the config.js. Default is 8080, but i had many troubles with this port…
          Test Myone:
          http.//timesoft-internet.box.ch:8089
          • Y Offline
            yours.mukul @psteimann
            @psteimann I’m using MMM-IFTTT module, this module require to set Webhooks as actions and my DNS as URL endpoint. I have checked my settings and the port forwarding and firewall are all set. But MagicMirror refuses the connection from IFTTT IP address. Because the IP address of IFTTT is not in whitelist.
            • K Offline
              krisalexroberts
              YOu have to spend a while sending webhooks requests, then compile a list and whitelist.
              IFTTT uses amazon AWS so it could be a massive list of addresses.
              • Y Offline
                yours.mukul @krisalexroberts
                @krisalexroberts said in IP White List:
                amazon
                I don’t think this is optimal solution, can’t we have port open for everyone? Like make it open to world, just like a website? It would be fun actually. By doing so I can watch my magic mirror anywhere I want.
                • K Offline
                  krisalexroberts
                  And so can the rest of the world.
                  0.0.0.0/0
