    System temperature : fetching...
    12 Posts 4 Posters 10.9k Views 3 Watching
      sebastiensaucier
      I installed the MMM-SystemTemperature by MichMich , but it still displays “System temperature: fetching…” and I can’t get the temperature.
      If I use /opt/vc/bin/vcgencmd measure_temp in the terminal it works fine, but not in the magic mirror app.
      I have a Raspberry Pi 3.
      Thanks for your help.
      • 0 Offline
        00conman
        How long have you had it fetch the system temperature? Also, you should tell this to the module author.
          sebastiensaucier
          It does this for hours, I never get the temperature. How can I contact the author?
          MichMichM 1 Reply Last reply Reply Quote 0
          • 0 Offline
            00conman
            Contact michmich he created the magic mirror.
            • P Offline
              paviro
              @00conman since @MichMich is on this forum, he will see :)
              – The Doctor
              • MichMichM Offline
                MichMich @sebastiensaucier
                @sebastiensaucier That’s weird … do you see any weird messages in the terminal?
                  sebastiensaucier
                  No just the normal text:
                  • 0 Offline
                    00conman
                    Just a thought, but could CPU load have anything to do with it?
                      sebastiensaucier
                      It’s around 10% of usage. So I don’t think it can cause the problem.
                      • MichMichM Offline
                        @sebastiensaucier could you modify the node_helper
                        change:
                        self.sendSocketNotification('TEMPERATURE', stdout.replace('temp=','').replace('\'','\°'));
                        to:
                        var temperature = stdout.replace('temp=','').replace('\'','\°');
                        console.log('Temperature: ' + temperature);
                        self.sendSocketNotification('TEMPERATURE', temperature);
                        And see if the temperature is logged?
                          sebastiensaucier
                          Nothing in the console. Where can I see the logs?
                          Also, I tried to erease all and do all the readme again, but nothing changed.
                          • P Offline
                            paviro
                            You can see the logs inside your terminal session. If you use pm2 execute pm2 logs mm to see the log! :)
                            – The Doctor
