    System temperature : fetching...
    12 Posts 4 Posters 11.0k Views 3 Watching
      sebastiensaucier
      It does this for hours, I never get the temperature. How can I contact the author?
      MichMichM 1 Reply Last reply
      • 0
        00conman
        Contact michmich he created the magic mirror.
          paviro
          @00conman since @MichMich is on this forum, he will see :)
          – The Doctor
          • MichMichM
            MichMich @sebastiensaucier
            @sebastiensaucier That’s weird … do you see any weird messages in the terminal?
              sebastiensaucier
              No just the normal text:
              • 0
                00conman
                Just a thought, but could CPU load have anything to do with it?
                  sebastiensaucier
                  It’s around 10% of usage. So I don’t think it can cause the problem.
                  • MichMichM
                    @sebastiensaucier could you modify the node_helper
                    change:
                    self.sendSocketNotification('TEMPERATURE', stdout.replace('temp=','').replace('\'','\°'));
                    to:
                    var temperature = stdout.replace('temp=','').replace('\'','\°');
                    console.log('Temperature: ' + temperature);
                    self.sendSocketNotification('TEMPERATURE', temperature);
                    And see if the temperature is logged?
                      sebastiensaucier
                      Nothing in the console. Where can I see the logs?
                      Also, I tried to erease all and do all the readme again, but nothing changed.
                        paviro
                        You can see the logs inside your terminal session. If you use pm2 execute pm2 logs mm to see the log! :)
                        – The Doctor
