    Problems with MagicMirror modules, Calendar, weather-forecast, newsfeed
    3 Posts 2 Posters 1.8k Views 2 Watching
      A Former User
      Hello,
      I have some Problems with modules at my MagicMirror. Actually I use the default modules but they don’t work as I want.
      At first my Code in config.js
      var config = {
      	port: 8080,
      	language: "de",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      						url: "url google-Calendar",
      						fetchInterval: "60000",
      						timeFormat: "relative",
      						displaySymbol: "false"
      						url: "url 2nd google-Calendar",
      			module: "currentweather",
      				locationID: "2871813",  //ID from http://www.openweathermap.org/help/city_list.txt
      				appid: "My Appid from openweathermap"
      			module: "weatherforecast",
      			module: "newsfeed",
      			position: "bottom_left",
      				feeds: [
      						title: "Nachrichten",
      						url: "http://www.tagesschau.de/xml/rss2"
      				showPublishDate: "false",
      				showSourceTitle: "true",
      				showDescription: "true",
      				updateInterval: "15000"
      My first problem is with the calendar-module
      It doesn’t matter what I use for config-parameter. I alwas get the calendar-symbol in front of the event.
      2nd Problem with weather-forecast.
      A lot of people have problems with this module. At least a lot of people say that it doesn’t show.
      At my program it also doesn’t work. But the currentweather is displayes. It’s the same appid. Also if I comment out the currentweather module the weather-forecast isn’t displayed.
      I also tried other weather-forecast modules but no one worked.
      My last problem is with the newsfed-module.
      The title isn’t displayed. The PublishDate is set “false”, but it’s displayed.
      So, I have a lot of problems with the configuration of the modules and I don’t know what I’m doing wrong.
      I hope anybody can help me with these problems.
      • P
        pjkoeleman
        @Johannes said in Problems with MagicMirror modules, Calendar, weather-forecast, newsfeed:
        First problem, I use MMM-MyCalendar witch has more options for config and is working great. Try this one. And there are errors in your config.sys
        				fetchInterval: 60000,
        				displaySymbol: false
        There are problems with Weather forecast, there is work in progress. Link to News Item.
        For your last problem there are some errors in your config.sys. Number and false/true never use “…” or ‘…’
          module: "newsfeed",
        		feeds: [
        		showPublishDate: false,
        		showSourceTitle: true,
        		showDescription: true,
        		updateInterval: 15000
          A Former User
          Thank you for your answer.
          I’ll remove the quotes at numbers and true/false. I also will try MMM-MyCalendar .
