    MMM-FAA-Delay
    20 Posts 5 Posters 13.5k Views 4 Watching
    • N Offline
      nigel-daniels @fwood04
      @fwood04 I’ve found some time and reworked the code so that you can provide an array of airport codes and display multiple airports correctly.
      You will need to re-clone the module and use the new format of configuration.
      I hope that helps.
      • N Offline
        nigel-daniels @nigel-daniels
        @nigel-daniels Update to fix a bug where the reported data on an airport can get assigned the wrong airport code. This is to support the updated configuration that allows for multiple airports, for example:
        module: 'MMM-FAA-Delay',
        position: 'top_left',
        header: 'Airport Delays',
        interval: 300000, // 5 min updates
        airports: ['SFO', 'SJC']
        F 1 Reply Last reply Reply Quote 1
        • F Offline
          fwood04 @nigel-daniels
          @nigel-daniels Sorry for the long delay, but thanks!
          • twosquirrelsT Offline
            twosquirrels
            This module is great, but how do I get rid of the weather? I already have a weather module, so this wastes valuable space. Thanks.
            EDIT: I answered my own questions. I just commented out this line in MMM-FAA-Delay.js:
              //wrapper.appendChild(weatherRow);
            N 2 Replies Last reply Reply Quote 0
            • N Offline
              nigel-daniels @twosquirrels
              @twosquirrels Glad you sorted it out. I figured the weather is useful if you are monitoring airports some distance away but if you live close to the one you track then I can see it’s redundant information.
              • N Offline
                nigel-daniels
                The FAA have update their API and as a result broke this module. There is an updated version now in the git repository. This update has two features:
                • It handles the new API correctly.
                • It now has a flag to block the display of the airport weather.
                On your magic mirror go into the MMM-FAA-Delay directory in the modules and run the following commands:
                git pull
                npm install
                This should update the MMM-FAA-Delay code then update it’s dependancies.
                • N Offline
                  @twosquirrels you may be seeing that the MMM-FAA-Delay module is broken, the FAA changed their code and did not let anyone know or put a proxy/web forward in place :( I have updated the code and added a flag displayWeather to the config so that when you update you don’t have to go in and hack the new code again.
                  twosquirrelsT 2 Replies Last reply Reply Quote 0
                  • N Offline
                    @fwood04 hi, you may be seeing errors for this module, the FAA changed stuff and broke the module, I’ve just fixed it so you should be good to update.
                      twosquirrels @nigel-daniels
                      @nigel-daniels
                      I did notice it was broken for the last couple days but didn’t check these forums until now. Thanks for the update! I’ll be updating today.
                        @nigel-daniels
                        It was driving me nuts, but the config is showWeather, not displayWeather :smiling_face_with_open_mouth_closed_eyes:
