    Display modules in a carousel
    29 Posts 8 Posters 28.1k Views 8 Watching
    • C Offline
      cnelso24 @PointPubMedia
      @PointPubMedia
      Did you ever figure this out? I’m interested in the same thing
      • I Offline
        izanbard @PointPubMedia
        @PointPubMedia @cnelso24 Hey, I have just had a PR accepted that adds several config options that should help you
        C 1 Reply Last reply Reply Quote 1
        • I Offline
          izanbard @amanzimdwini
          @amanzimdwini have a look at the latest version, I think it will have some of the features you are looking for
          • PointPubMediaP Offline
            PointPubMedia
            Thanks!
            Is it possible to rotate multiple module definition of the same name ? I mean I’m using MMM-iFrame couple of time on the screen but would like to have only 1 place with multiple iFrame rotating…
            • I Offline
              @PointPubMedia yes, if all your iframes are in the same “position” (say top_left)on the page then this config should do it:
                          module: 'MMM-Carousel',
                              transitionInterval: 10000,
                              mode: 'positional',
                              top_left: {enabled: true, ignoreModules: [], overrideTransitionInterval: 10000},
              • C Offline
                cnelso24 @izanbard
                @izanbard
                works great, thank you!
                  PointPubMedia
                  @izanbard But with positional I can’t ignore module ?
                  • I Offline
                    @PointPubMedia yes you can, but you do it by position. Read the config above and see if you can work out in the positional settings you ignore modules per position. Hint it is between enabled and overrideTransitionInterval.
                    PointPubMediaP 1 Reply Last reply Reply Quote 0
                      PointPubMedia @izanbard
                      @izanbard said in Display modules in a carousel:
                      Working fine ;)
                      That’s perfect!
                      thanks mate!
                      • 3 / 3
