    MMM-Remote-Control-Repository
    5 Posts 2 Posters 4.0k Views 3 Watching
    • ? Offline
      [[global:former-user]]
      This module automatically updates modules.json of MMM-Remote-Control with information of https://github.com/MichMich/MagicMirror/wiki/MagicMirror²-Modules
      As you know, MMM-Remote-Control is a great module, I think it is essentially needed to manage your MagicMirror. But installable modules are limited by modules.json. And it was managed by manual. The last update was 7 months ago.
      After conversation with @Jopyth in Slack, I thought it could be a good option to provide automatically updated modules.json
      https://github.com/MichMich/MagicMirror/wiki/MagicMirror%C2%B2-Modules would be working as a deFacto repository for MagicMirror modules. So installable modules data was derived from there.
      Download:
      [card:eouia/MMM-Remote-Control-Repository]
      • G Offline
        gismo2006
        I have a little problem with your module. I hae install correctly and my MagicMirror starts. Now I have start with npm start dev because of an other problem. And I found two errors atr the console.
        Failed to load resource: the server responded with a status of 404 (Not Found)
        Error on loading script: modules/MMM-Remote-Control-Repository//MMM-Remote-Control-Repository.js
        and
        Can you help me?
        greets gismo
        • ? Offline
          [[global:former-user]] @gismo2006
          @gismo2006
          The message means MMM-Remote-Control-Repository was not installed properly.
          Check if the source is located in proper position.
          cd {your magicmirror directory}/modules/MMM-Remote-Control-Repository
          ls
          Are the directory and files located properly?
          • G Offline
            gismo2006
            ok I found the problem. I have install like you write, but the module folder wasn´t called MMM-Remote-Control-Repository the created folder was named RC-Repository. I have changed the name and now there are no errors shown.
            Thank you
            • ? Offline
              @gismo2006
              Sorry. That was my typo miss. I fix it now.
