Solved Alexa pi install, mic doenst work?
I order the Same USB soundcard like you today… I hope that it arrives tomorrow, do I have to install that also?
@Milad222
It’s plug&play device and no need to install any drivers. Hope you it will help you.
I’m currently configuring Jarvis assistant. Did you hear about this?
Let me know if you will success with Alexa P
Best, -
@aro28
Javaris… i hear about that… but never try… does it work good?tonight i will try the USB soundcard! you will hear it from me
Greatz
So i finally have the 3D usb soundcard… with a 3.5mm jack mic… how verder now? What do i have to do…
Thnx to @aro28 Alexa pi work! Thnx a lot!
Hi, I am confused on a matter. I have everything in the Alexa service set up and running but I have to scream in the mic to actually hear Alexa say “Yes?”. Does anyone know how I could fix this other than using the alsamixer tool? I go to alsamixer, select my usb mic pnp device, go to capture, raise it to 100, then esc out. Please help me…
