    Alexa pi install, mic doenst work?
    16 Posts 4 Posters 9.6k Views 4 Watching
    • aro28A Offline
      aro28 @Milad222
      @Milad222
      I bought USB 3D sound card adapter since my Pi3 hasn’t Mic port and than i connected my jack 3.5 Microphone to it .
      If you have another USB HD camera with built-ed Mic you have to disable it since it will not work properly with your speech recognition software. I faced recently with this problem. I couldn’t configure it.
      If you have USB HD camera with built-ed Mic please let me know and i show you how to disable it.
      Best,
        Milad222 @aro28
        @aro28 said in Alexa pi install, mic doenst work?:
        Hi Thanx for replying me, i have a logitac usb camera with buildin cam… the mic work in the pluseaudi pannel… i see it moving at the input section…
        so i think i have to disable it…? i have also teamviewer installed on my laptop you can connect me if its to difficult to explane… :)
          A Former User @Milad222
          @Milad222
          I think it could be related with permission of account.
          As I know, Alexa Pi is running with Deamon mode, it means, the account of Alexa Pi is different with your personal account which you had tested audio with.(maybe pulse audio)
          I have no idea how to solve because I’m not an expert, but most of the cases seem to be related to that point in using Alexa Pi.
            Milad222 @aro28
            This is printscreen of my settings and error…
              @Milad222
              Can you record and play with these commands? Does it work?
              arecord -d 10 test.wav && aplay test.wav
                Milad222 @Guest
                @Sean said in Alexa pi install, mic doenst work?:
                Yes that works…
                  Milad222 @Milad222
                  @Milad222 said in Alexa pi install, mic doenst work?:
                  Yes that works…
                  pi@raspberrypi:~ $ arecord -d 10 test.wav && aplay test.wav
                  Recording WAVE ‘test.wav’ : Unsigned 8 bit, Rate 8000 Hz, Mono
                  Playing WAVE ‘test.wav’ : Unsigned 8 bit, Rate 8000 Hz, Mono
                  pi@raspberrypi:~ $
                  pi@raspberrypi:~ $ aplay test.wav
                  pi@raspberrypi:~ $
                    @Milad222
                    I’m not an expert, but Only I can say is…
                    • The error message caused by sound configuration fail.
                    • AlexaPi cannot understand your device “plughw:…” currently.
                    • I think it is related to alexapi daemon account and your personal account settings.
                    • https://github.com/alexa-pi/AlexaPi/wiki/Audio-setup-&-debugging This could be helpful.
                    Anyway, this is not realted with MagicMirror. You’d better get help from AlexaPi develpers or users on gitHub(or wiki)
                    • aro28A Offline
                      aro28
                      Since i installed 3D sound card(external USB card with speaker and Mic) i disabled other internal HD web camera’s Microphone which came with my Touch Screen monitor. I used usual 3.5 mm jack mic.
                      1. Go to- -> sudo nano /lib/modprobe.d/aliases.conf
                      ##options snd-pcsp index=-2 - This is my USB Mic which is came with internal HD camera on my monitor.
                      options snd-usb-audio index=-2
                      options cx88_alsa index=-2
                      options snd-atiixp-modem index=-2
                      options snd-intel8x0m index=-2
                      2. Go to --> sudo nano /etc/modprobe.d/raspi-blacklist.conf and added below command
                      blacklist snd_bcm2835
                      Above “snd_bcm2835” is my internal sound card
                      That’s all.
                        Milad222 @aro28
                        @aro28
                        I order the Same USB soundcard like you today… I hope that it arrives tomorrow, do I have to install that also?
                        aro28A 1 Reply Last reply Reply Quote 0
                        • aro28A Offline
                          aro28 @Milad222
                          @Milad222
                          It’s plug&play device and no need to install any drivers. Hope you it will help you.
                          I’m currently configuring Jarvis assistant. Did you hear about this?
                          Let me know if you will success with Alexa P
                          Best,
                            Milad222 @aro28
                            @aro28
                            Javaris… i hear about that… but never try… does it work good?
                            tonight i will try the USB soundcard! you will hear it from me
                            Greatz
                              Milad222
                              So i finally have the 3D usb soundcard… with a 3.5mm jack mic… how verder now? What do i have to do…
                                Milad222
                                Thnx to @aro28 Alexa pi work! Thnx a lot!
                                • shadeajS Offline
                                  shadeaj
                                  Hi, I am confused on a matter. I have everything in the Alexa service set up and running but I have to scream in the mic to actually hear Alexa say “Yes?”. Does anyone know how I could fix this other than using the alsamixer tool? I go to alsamixer, select my usb mic pnp device, go to capture, raise it to 100, then esc out. Please help me…
