    Alexa pi install, mic doenst work?
    16 Posts 4 Posters 8.9k Views 4 Watching
    • aro28A Offline
      aro28 @Milad222
      @Milad222
      I bought USB 3D sound card adapter since my Pi3 hasn’t Mic port and than i connected my jack 3.5 Microphone to it .
      If you have another USB HD camera with built-ed Mic you have to disable it since it will not work properly with your speech recognition software. I faced recently with this problem. I couldn’t configure it.
      If you have USB HD camera with built-ed Mic please let me know and i show you how to disable it.
      Best,
        Milad222 @aro28
        @aro28 said in Alexa pi install, mic doenst work?:
        Hi Thanx for replying me, i have a logitac usb camera with buildin cam… the mic work in the pluseaudi pannel… i see it moving at the input section…
        so i think i have to disable it…? i have also teamviewer installed on my laptop you can connect me if its to difficult to explane… :)
          A Former User @Milad222
          @Milad222
          I think it could be related with permission of account.
          As I know, Alexa Pi is running with Deamon mode, it means, the account of Alexa Pi is different with your personal account which you had tested audio with.(maybe pulse audio)
          I have no idea how to solve because I’m not an expert, but most of the cases seem to be related to that point in using Alexa Pi.
            Milad222 @aro28
            This is printscreen of my settings and error…
              @Milad222
              Can you record and play with these commands? Does it work?
              arecord -d 10 test.wav && aplay test.wav
                Milad222 @Guest
                @Sean said in Alexa pi install, mic doenst work?:
                Yes that works…
                  Milad222 @Milad222
                  @Milad222 said in Alexa pi install, mic doenst work?:
                  Yes that works…
                  pi@raspberrypi:~ $ arecord -d 10 test.wav && aplay test.wav
                  Recording WAVE ‘test.wav’ : Unsigned 8 bit, Rate 8000 Hz, Mono
                  Playing WAVE ‘test.wav’ : Unsigned 8 bit, Rate 8000 Hz, Mono
                  pi@raspberrypi:~ $
                  pi@raspberrypi:~ $ aplay test.wav
                  pi@raspberrypi:~ $
                    @Milad222
                    I’m not an expert, but Only I can say is…
                    • The error message caused by sound configuration fail.
                    • AlexaPi cannot understand your device “plughw:…” currently.
                    • I think it is related to alexapi daemon account and your personal account settings.
                    • https://github.com/alexa-pi/AlexaPi/wiki/Audio-setup-&-debugging This could be helpful.
                    Anyway, this is not realted with MagicMirror. You’d better get help from AlexaPi develpers or users on gitHub(or wiki)
                    • aro28A Offline
                      aro28
                      Since i installed 3D sound card(external USB card with speaker and Mic) i disabled other internal HD web camera’s Microphone which came with my Touch Screen monitor. I used usual 3.5 mm jack mic.
                      1. Go to- -> sudo nano /lib/modprobe.d/aliases.conf
                      ##options snd-pcsp index=-2 - This is my USB Mic which is came with internal HD camera on my monitor.
                      options snd-usb-audio index=-2
                      options cx88_alsa index=-2
                      options snd-atiixp-modem index=-2
                      options snd-intel8x0m index=-2
                      2. Go to --> sudo nano /etc/modprobe.d/raspi-blacklist.conf and added below command
                      blacklist snd_bcm2835
                      Above “snd_bcm2835” is my internal sound card
                      That’s all.
                        Milad222 @aro28
                        @aro28
                        I order the Same USB soundcard like you today… I hope that it arrives tomorrow, do I have to install that also?
                        aro28A 1 Reply Last reply Reply Quote 0
