    Alexa pi install, mic doenst work?
    16 Posts 4 Posters 8.9k Views 4 Watching
      Milad222 @aro28
      This is printscreen of my settings and error…
        A Former User @Milad222
        @Milad222
        Can you record and play with these commands? Does it work?
        arecord -d 10 test.wav && aplay test.wav
          Milad222 @Guest
          @Sean said in Alexa pi install, mic doenst work?:
          Yes that works…
            Milad222 @Milad222
            @Milad222 said in Alexa pi install, mic doenst work?:
            Yes that works…
            pi@raspberrypi:~ $ arecord -d 10 test.wav && aplay test.wav
            Recording WAVE ‘test.wav’ : Unsigned 8 bit, Rate 8000 Hz, Mono
            Playing WAVE ‘test.wav’ : Unsigned 8 bit, Rate 8000 Hz, Mono
            pi@raspberrypi:~ $
            pi@raspberrypi:~ $ aplay test.wav
            pi@raspberrypi:~ $
              @Milad222
              I’m not an expert, but Only I can say is…
              • The error message caused by sound configuration fail.
              • AlexaPi cannot understand your device “plughw:…” currently.
              • I think it is related to alexapi daemon account and your personal account settings.
              • https://github.com/alexa-pi/AlexaPi/wiki/Audio-setup-&-debugging This could be helpful.
              Anyway, this is not realted with MagicMirror. You’d better get help from AlexaPi develpers or users on gitHub(or wiki)
              • aro28A Offline
                aro28
                Since i installed 3D sound card(external USB card with speaker and Mic) i disabled other internal HD web camera’s Microphone which came with my Touch Screen monitor. I used usual 3.5 mm jack mic.
                1. Go to- -> sudo nano /lib/modprobe.d/aliases.conf
                ##options snd-pcsp index=-2 - This is my USB Mic which is came with internal HD camera on my monitor.
                options snd-usb-audio index=-2
                options cx88_alsa index=-2
                options snd-atiixp-modem index=-2
                options snd-intel8x0m index=-2
                2. Go to --> sudo nano /etc/modprobe.d/raspi-blacklist.conf and added below command
                blacklist snd_bcm2835
                Above “snd_bcm2835” is my internal sound card
                That’s all.
                  Milad222 @aro28
                  @aro28
                  I order the Same USB soundcard like you today… I hope that it arrives tomorrow, do I have to install that also?
                  aro28A 1 Reply Last reply Reply Quote 0
                  • aro28A Offline
                    aro28 @Milad222
                    @Milad222
                    It’s plug&play device and no need to install any drivers. Hope you it will help you.
                    I’m currently configuring Jarvis assistant. Did you hear about this?
                    Let me know if you will success with Alexa P
                    Best,
                      Milad222 @aro28
                      @aro28
                      Javaris… i hear about that… but never try… does it work good?
                      tonight i will try the USB soundcard! you will hear it from me
                      Greatz
                        Milad222
                        So i finally have the 3D usb soundcard… with a 3.5mm jack mic… how verder now? What do i have to do…
