    Alexa pi install, mic doenst work?
    16 Posts 4 Posters 8.9k Views 4 Watching
      A Former User @Milad222
      @Milad222
      I think it could be related with permission of account.
      As I know, Alexa Pi is running with Deamon mode, it means, the account of Alexa Pi is different with your personal account which you had tested audio with.(maybe pulse audio)
      I have no idea how to solve because I’m not an expert, but most of the cases seem to be related to that point in using Alexa Pi.
        Milad222 @aro28
        This is printscreen of my settings and error…
          @Milad222
          Can you record and play with these commands? Does it work?
          arecord -d 10 test.wav && aplay test.wav
            Milad222 @Guest
            @Sean said in Alexa pi install, mic doenst work?:
            Yes that works…
              Milad222 @Milad222
              @Milad222 said in Alexa pi install, mic doenst work?:
              Yes that works…
              pi@raspberrypi:~ $ arecord -d 10 test.wav && aplay test.wav
              Recording WAVE ‘test.wav’ : Unsigned 8 bit, Rate 8000 Hz, Mono
              Playing WAVE ‘test.wav’ : Unsigned 8 bit, Rate 8000 Hz, Mono
              pi@raspberrypi:~ $
              pi@raspberrypi:~ $ aplay test.wav
              pi@raspberrypi:~ $
                @Milad222
                I’m not an expert, but Only I can say is…
                • The error message caused by sound configuration fail.
                • AlexaPi cannot understand your device “plughw:…” currently.
                • I think it is related to alexapi daemon account and your personal account settings.
                • https://github.com/alexa-pi/AlexaPi/wiki/Audio-setup-&-debugging This could be helpful.
                Anyway, this is not realted with MagicMirror. You’d better get help from AlexaPi develpers or users on gitHub(or wiki)
                • aro28A Offline
                  aro28
                  Since i installed 3D sound card(external USB card with speaker and Mic) i disabled other internal HD web camera’s Microphone which came with my Touch Screen monitor. I used usual 3.5 mm jack mic.
                  1. Go to- -> sudo nano /lib/modprobe.d/aliases.conf
                  ##options snd-pcsp index=-2 - This is my USB Mic which is came with internal HD camera on my monitor.
                  options snd-usb-audio index=-2
                  options cx88_alsa index=-2
                  options snd-atiixp-modem index=-2
                  options snd-intel8x0m index=-2
                  2. Go to --> sudo nano /etc/modprobe.d/raspi-blacklist.conf and added below command
                  blacklist snd_bcm2835
                  Above “snd_bcm2835” is my internal sound card
                  That’s all.
                    Milad222 @aro28
                    @aro28
                    I order the Same USB soundcard like you today… I hope that it arrives tomorrow, do I have to install that also?
                    aro28A 1 Reply Last reply Reply Quote 0
                    • aro28A Offline
                      aro28 @Milad222
                      @Milad222
                      It’s plug&play device and no need to install any drivers. Hope you it will help you.
                      I’m currently configuring Jarvis assistant. Did you hear about this?
                      Let me know if you will success with Alexa P
                      Best,
                        Milad222 @aro28
                        @aro28
                        Javaris… i hear about that… but never try… does it work good?
                        tonight i will try the USB soundcard! you will hear it from me
                        Greatz
