    Alexa pi install, mic doenst work?
    16 Posts 4 Posters 9.0k Views 4 Watching
      Milad222
      Hello everyone…
      I hope someone of you there can help me with the alexa pi…
      when i start alexa pi by sudo systemctl start AlexaPi.service and than checkinhg the status by sudo systemctl status AlexaPi.service i have got this error…
      pi@raspberrypi:~ $ sudo systemctl status AlexaPi.service
      ● AlexaPi.service - Alexa client for all your devices
      Loaded: loaded (/usr/lib/systemd/system/AlexaPi.service; enabled)
      Active: failed (Result: exit-code) since Fri 2017-10-13 18:22:22 CEST; 1min 14s ago
      Docs: https://github.com/alexa-pi/AlexaPi/wiki
      Process: 1320 ExecStart=/usr/bin/python /opt/AlexaPi/src/main.py --daemon (code=exited, status=1/FAILURE)
      Main PID: 1320 (code=exited, status=1/FAILURE)
      Oct 13 18:22:22 raspberrypi python[1320]: ALSA lib pcm.c:2239:(snd_pcm_open_…e
      Oct 13 18:22:22 raspberrypi python[1320]: ALSA lib pcm_dmix.c:1022:(snd_pcm_…e
      Oct 13 18:22:22 raspberrypi python[1320]: connect(2) call to /tmp/jack-999/d…)
      Oct 13 18:22:22 raspberrypi python[1320]: attempt to connect to server failed
      Oct 13 18:22:22 raspberrypi python[1320]: CRITICAL: Your input_device 'plugh…:
      Oct 13 18:22:22 raspberrypi python[1320]: pulse
      Oct 13 18:22:22 raspberrypi python[1320]: default
      Oct 13 18:22:22 raspberrypi systemd[1]: AlexaPi.service: main process exited…E
      Oct 13 18:22:22 raspberrypi systemd[1]: Unit AlexaPi.service entered failed …
      Hint: Some lines were ellipsized, use -l to show in full.
      i think its the sound card but i dont know how to install and configure the sound card…
      i install teamvierwer so mayb someone overthere van help me? :) thnx
      aro28A 1 Reply Last reply Reply Quote 0
      • aro28A Offline
        aro28 @Milad222
        @Milad222
        I bought USB 3D sound card adapter since my Pi3 hasn’t Mic port and than i connected my jack 3.5 Microphone to it .
        If you have another USB HD camera with built-ed Mic you have to disable it since it will not work properly with your speech recognition software. I faced recently with this problem. I couldn’t configure it.
        If you have USB HD camera with built-ed Mic please let me know and i show you how to disable it.
        Best,
          Milad222 @aro28
          @aro28 said in Alexa pi install, mic doenst work?:
          Hi Thanx for replying me, i have a logitac usb camera with buildin cam… the mic work in the pluseaudi pannel… i see it moving at the input section…
          so i think i have to disable it…? i have also teamviewer installed on my laptop you can connect me if its to difficult to explane… :)
            A Former User @Milad222
            @Milad222
            I think it could be related with permission of account.
            As I know, Alexa Pi is running with Deamon mode, it means, the account of Alexa Pi is different with your personal account which you had tested audio with.(maybe pulse audio)
            I have no idea how to solve because I’m not an expert, but most of the cases seem to be related to that point in using Alexa Pi.
              Milad222 @aro28
              This is printscreen of my settings and error…
                @Milad222
                Can you record and play with these commands? Does it work?
                arecord -d 10 test.wav && aplay test.wav
                  Milad222 @Guest
                  @Sean said in Alexa pi install, mic doenst work?:
                  Yes that works…
                    Milad222 @Milad222
                    @Milad222 said in Alexa pi install, mic doenst work?:
                    Yes that works…
                    pi@raspberrypi:~ $ arecord -d 10 test.wav && aplay test.wav
                    Recording WAVE ‘test.wav’ : Unsigned 8 bit, Rate 8000 Hz, Mono
                    Playing WAVE ‘test.wav’ : Unsigned 8 bit, Rate 8000 Hz, Mono
                    pi@raspberrypi:~ $
                    pi@raspberrypi:~ $ aplay test.wav
                    pi@raspberrypi:~ $
                      @Milad222
                      I’m not an expert, but Only I can say is…
                      • The error message caused by sound configuration fail.
                      • AlexaPi cannot understand your device “plughw:…” currently.
                      • I think it is related to alexapi daemon account and your personal account settings.
                      • https://github.com/alexa-pi/AlexaPi/wiki/Audio-setup-&-debugging This could be helpful.
                      Anyway, this is not realted with MagicMirror. You’d better get help from AlexaPi develpers or users on gitHub(or wiki)
                      • aro28A Offline
                        aro28
                        Since i installed 3D sound card(external USB card with speaker and Mic) i disabled other internal HD web camera’s Microphone which came with my Touch Screen monitor. I used usual 3.5 mm jack mic.
                        1. Go to- -> sudo nano /lib/modprobe.d/aliases.conf
                        ##options snd-pcsp index=-2 - This is my USB Mic which is came with internal HD camera on my monitor.
                        options snd-usb-audio index=-2
                        options cx88_alsa index=-2
                        options snd-atiixp-modem index=-2
                        options snd-intel8x0m index=-2
                        2. Go to --> sudo nano /etc/modprobe.d/raspi-blacklist.conf and added below command
                        blacklist snd_bcm2835
                        Above “snd_bcm2835” is my internal sound card
                        That’s all.
                          Milad222 @aro28
                          @aro28
                          I order the Same USB soundcard like you today… I hope that it arrives tomorrow, do I have to install that also?
                          • aro28A Offline
                            aro28 @Milad222
                            @Milad222
                            It’s plug&play device and no need to install any drivers. Hope you it will help you.
                            I’m currently configuring Jarvis assistant. Did you hear about this?
                            Let me know if you will success with Alexa P
                            Best,
                              Milad222 @aro28
                              @aro28
                              Javaris… i hear about that… but never try… does it work good?
                              tonight i will try the USB soundcard! you will hear it from me
                              Greatz
                                Milad222
                                So i finally have the 3D usb soundcard… with a 3.5mm jack mic… how verder now? What do i have to do…
                                  Milad222
                                  Thnx to @aro28 Alexa pi work! Thnx a lot!
                                  • shadeajS Offline
                                    shadeaj
                                    Hi, I am confused on a matter. I have everything in the Alexa service set up and running but I have to scream in the mic to actually hear Alexa say “Yes?”. Does anyone know how I could fix this other than using the alsamixer tool? I go to alsamixer, select my usb mic pnp device, go to capture, raise it to 100, then esc out. Please help me…
