    Alexa pi install, mic doenst work?
    16 Posts 4 Posters 9.7k Views 4 Watching
      A Former User @Milad222
      @Milad222
      Can you record and play with these commands? Does it work?
      arecord -d 10 test.wav && aplay test.wav
      M 1 Reply Last reply
        Milad222 @Guest
        @Sean said in Alexa pi install, mic doenst work?:
        Yes that works…
          Milad222 @Milad222
          @Milad222 said in Alexa pi install, mic doenst work?:
          Yes that works…
          pi@raspberrypi:~ $ arecord -d 10 test.wav && aplay test.wav
          Recording WAVE ‘test.wav’ : Unsigned 8 bit, Rate 8000 Hz, Mono
          Playing WAVE ‘test.wav’ : Unsigned 8 bit, Rate 8000 Hz, Mono
          pi@raspberrypi:~ $
          pi@raspberrypi:~ $ aplay test.wav
          pi@raspberrypi:~ $
          ? 1 Reply Last reply
            @Milad222
            I’m not an expert, but Only I can say is…
            • The error message caused by sound configuration fail.
            • AlexaPi cannot understand your device “plughw:…” currently.
            • I think it is related to alexapi daemon account and your personal account settings.
            • https://github.com/alexa-pi/AlexaPi/wiki/Audio-setup-&-debugging This could be helpful.
            Anyway, this is not realted with MagicMirror. You’d better get help from AlexaPi develpers or users on gitHub(or wiki)
            • aro28A
              aro28
              Since i installed 3D sound card(external USB card with speaker and Mic) i disabled other internal HD web camera’s Microphone which came with my Touch Screen monitor. I used usual 3.5 mm jack mic.
              1. Go to- -> sudo nano /lib/modprobe.d/aliases.conf
              ##options snd-pcsp index=-2 - This is my USB Mic which is came with internal HD camera on my monitor.
              options snd-usb-audio index=-2
              options cx88_alsa index=-2
              options snd-atiixp-modem index=-2
              options snd-intel8x0m index=-2
              2. Go to --> sudo nano /etc/modprobe.d/raspi-blacklist.conf and added below command
              blacklist snd_bcm2835
              Above “snd_bcm2835” is my internal sound card
              That’s all.
                Milad222 @aro28
                @aro28
                I order the Same USB soundcard like you today… I hope that it arrives tomorrow, do I have to install that also?
                aro28A 1 Reply Last reply
                • aro28A
                  aro28 @Milad222
                  @Milad222
                  It’s plug&play device and no need to install any drivers. Hope you it will help you.
                  I’m currently configuring Jarvis assistant. Did you hear about this?
                  Let me know if you will success with Alexa P
                  Best,
                    Milad222 @aro28
                    @aro28
                    Javaris… i hear about that… but never try… does it work good?
                    tonight i will try the USB soundcard! you will hear it from me
                    Greatz
                      Milad222
                      So i finally have the 3D usb soundcard… with a 3.5mm jack mic… how verder now? What do i have to do…
                        Milad222
                        Thnx to @aro28 Alexa pi work! Thnx a lot!
                        • shadeajS
                          shadeaj
                          Hi, I am confused on a matter. I have everything in the Alexa service set up and running but I have to scream in the mic to actually hear Alexa say “Yes?”. Does anyone know how I could fix this other than using the alsamixer tool? I go to alsamixer, select my usb mic pnp device, go to capture, raise it to 100, then esc out. Please help me…
