    Alexa pi install, mic doenst work?
    16 Posts 4 Posters 8.7k Views 4 Watching
      Milad222 @aro28
      @aro28 said in Alexa pi install, mic doenst work?:
      USB HD camera with built-ed Mic please let
      Hi Thanx for replying me, i have a logitac usb camera with buildin cam… the mic work in the pluseaudi pannel… i see it moving at the input section…
      so i think i have to disable it…? i have also teamviewer installed on my laptop you can connect me if its to difficult to explane… :)
        A Former User @Milad222
        @Milad222
        I think it could be related with permission of account.
        As I know, Alexa Pi is running with Deamon mode, it means, the account of Alexa Pi is different with your personal account which you had tested audio with.(maybe pulse audio)
        I have no idea how to solve because I’m not an expert, but most of the cases seem to be related to that point in using Alexa Pi.
          Milad222 @aro28
          This is printscreen of my settings and error…
            @Milad222
            Can you record and play with these commands? Does it work?
            arecord -d 10 test.wav && aplay test.wav
              Milad222 @Guest
              @Sean said in Alexa pi install, mic doenst work?:
              Yes that works…
                Milad222 @Milad222
                @Milad222 said in Alexa pi install, mic doenst work?:
                Yes that works…
                pi@raspberrypi:~ $ arecord -d 10 test.wav && aplay test.wav
                Recording WAVE ‘test.wav’ : Unsigned 8 bit, Rate 8000 Hz, Mono
                Playing WAVE ‘test.wav’ : Unsigned 8 bit, Rate 8000 Hz, Mono
                pi@raspberrypi:~ $
                pi@raspberrypi:~ $ aplay test.wav
                pi@raspberrypi:~ $
                  @Milad222
                  I’m not an expert, but Only I can say is…
                  • The error message caused by sound configuration fail.
                  • AlexaPi cannot understand your device “plughw:…” currently.
                  • I think it is related to alexapi daemon account and your personal account settings.
                  • https://github.com/alexa-pi/AlexaPi/wiki/Audio-setup-&-debugging This could be helpful.
                  Anyway, this is not realted with MagicMirror. You’d better get help from AlexaPi develpers or users on gitHub(or wiki)
                  • aro28A Offline
                    aro28
                    Since i installed 3D sound card(external USB card with speaker and Mic) i disabled other internal HD web camera’s Microphone which came with my Touch Screen monitor. I used usual 3.5 mm jack mic.
                    1. Go to- -> sudo nano /lib/modprobe.d/aliases.conf
                    ##options snd-pcsp index=-2 - This is my USB Mic which is came with internal HD camera on my monitor.
                    options snd-usb-audio index=-2
                    options cx88_alsa index=-2
                    options snd-atiixp-modem index=-2
                    options snd-intel8x0m index=-2
                    2. Go to --> sudo nano /etc/modprobe.d/raspi-blacklist.conf and added below command
                    blacklist snd_bcm2835
                    Above “snd_bcm2835” is my internal sound card
                    That’s all.
                      Milad222 @aro28
                      @aro28
                      I order the Same USB soundcard like you today… I hope that it arrives tomorrow, do I have to install that also?
                      aro28A 1 Reply Last reply Reply Quote 0
                      • aro28A Offline
                        aro28 @Milad222
                        @Milad222
                        It’s plug&play device and no need to install any drivers. Hope you it will help you.
                        I’m currently configuring Jarvis assistant. Did you hear about this?
                        Let me know if you will success with Alexa P
                        Best,
