Help! semester project can't figure out facial recognition
Hello all,
First I wanna say I’m new to forums in general so if I posted this in the wrong place a guiding hand would be much appreciated. Secondly I’m kinda new to rpi and super new to magic mirror. I’ve done a couple cool projects but this facial recognition is kicking my but! I’ve been researching and trying different things off and on for about two weeks now trying to figure this out with no luck. I tried using 50+ pictures with all three algorithms, I’ve completely reloaded raspbian, magic mirror^2, and MMM-Facial-Recognition with the only good that came from it was getting Facial-Recognition-Tools to start working. When I run ‘facerecognition.py’ it was able to figure out my buddy Dakota and myself but when I try to run it with the magic mirror it seems like it’s not doing anything. Below I have all three different Magic Mirror config.js files i used (in an attempt to try to figure something/ anything out), my three different “classes” (hopefully that’s what i made), MMM-Facial-Recognition-Tools-master config.py file, and the Terminal output with each config.js file (1-3) i tried and the out come. if someone could point me in the right direction of what I’m doing wrong I would GREATLY appreciated! Thanks
Magic Mirror Config.js #1:
/* Magic Mirror Config Sample
*- By Michael Teeuw http://michaelteeuw.nl
- MIT Licensed.
- For more information how you can configurate this file
- See https://github.com/MichMich/MagicMirror#configuration
var config = {
address: “localhost”, // Address to listen on, can be:
// - “localhost”, “127.0.0.1”, “::1” to listen on loopback interface
// - “”, “0.0.0.0”, “::” to listen on any interface
// Default, when address config is left out, is “localhost”
port: 8080,
ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
// [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
// [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],language: “en”,
timeFormat: 12,
units: “imperial”,modules: [
module: “alert”,
module: “updatenotification”,
position: “top_bar”
module: “clock”,
position: “top_left”
module: “calendar”,
header: “US Holidays”,
position: “top_left”,
symbol: "calendar-check-o ",
url: “webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics”
// module: “compliments”,
// position: “lower_third”
module: “currentweather”,
position: “top_right”,
locationID: “5303752”, //ID from http://www.openweathermap.org/help/city_list.txt
appid: “key”
module: “weatherforecast”,
header: “Weather Forecast”,
appid: “key”
// module: “MMM-Hello-Mirror”,
// position: “lower_third”,
// config: {
// language: “en”,
// voice: “US English Female”,
// wakeUp: “Hello Mirror”
module: “MMM-Facial-Recognition”,
// 1=LBPH | 2=Fisher | 3=Eigen
recognitionAlgorithm: 3,
// Threshold for the confidence of a recognized face before it’s considered a
// positive match. Confidence values below this threshold will be considered
// a positive match because the lower the confidence value, or distance, the
// more confident the algorithm is that the face was correctly detected.
lbphThreshold: 50,
fisherThreshold: 250,
eigenThreshold: 3000,
// force the use of a usb webcam on raspberry pi (on other platforms this is always true automatically)
useUSBCam: false,
// Path to your training xml
trainingFile: ‘/home/pi/MagicMirror/modules/MMM-Facial-Recognition-master’,
// recognition intervall in seconds (smaller number = faster but CPU intens!)
interval: 2,
// Logout delay after last recognition so that a user does not get instantly logged out if he turns away from the mirror for a few seconds
logoutDelay: 15,
// Array with usernames (copy and paste from training script)
users: [‘Nick’,‘nick’],
//Module set used for strangers and if no user is detected
defaultClass: “default1”,
//Set of modules which should be shown for every user
everyoneClass: “everyone”,
// Boolean to toggle welcomeMessage
welcomeMessage: true
// module: “everyone”,
// //Set your classes here seperated by a space.
// //Shown for all users
// classes: “everyone”
// module: “dakota”,
// position: “top_bar”,
// //Only shown for dakota
// classes: “dakota”
module: “Nick”,
//Only shown for Nick
classes: “Nick”
module: “newsfeed”,
position: “bottom_bar”,
feeds: [
title: “Google News”,
url: “https://news.google.com/output=rss”
title: “CNN”,
url: “http://rss.cnn.com/rss/cnn_topstories.rss”
title: “Yahoo News”,
url: “http://news.yahoo.com/rss”
title: “ESPN”,
url: “http://www.espn.com/espn/rss/news”
title: “New York Times”,
url: “http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml”
showSourceTitle: true,
showPublishDate: true
if (typeof module !== “undefined”) {module.exports = config;}
Magic Mirror Config.js#2:
- MIT Licensed.
var config = {
port: 8080,
timeFormat: 12,
recognitionAlgorithm: 1,
lbphThreshold: 50,
useUSBCam: false,
interval: 2,
logoutDelay: 15,
users: [‘Nick’],
module: “everyone”,
classes: “everyone”
module: “default1”,
//Only shown for default1
classes: “default1”
module: “Nick”,
classes: “Nick”
Magic Mirror Config.js #3:
- MIT Licensed.
var config = {
port: 8080,
timeFormat: 12,
lbphThreshold: 50,
useUSBCam: false,
interval: 2,
logoutDelay: 15,
users: [‘Nick’],
MMM-Facial-Recognition-Tools-master config.py:
#!/usr/bin/env python
coding: utf8
“”"MMM-Facial-Recognition - MagicMirror Module
Face Recognition training script config
The MIT License (MIT)Copyright
2016 Paul-Vincent Roll (MIT License)
Based on work by Tony DiCola (Copyright 2013) (MIT License)
import inspect
import os
import platform
import cv2(CV_MAJOR_VER, CV_MINOR_VER, mv1, mv2) = cv2.version.split(“.”)
_platform = platform.system().lower()
path_to_file = os.path.dirname(os.path.abspath(inspect.getfile(inspect.currentframe())))RECOGNITION_ALGORITHM = 1
POSITIVE_THRESHOLD = 80def set_recognition_algorithm(algorithm):
if algorithm < 1 or algorithm > 3:
print(“WARNING: face algorithm must be in the range 1-3”)
os._exit(1)
RECOGNITION_ALGORITHM = algorithm
# Threshold for the confidence of a recognized face before it’s
# considered a positive match. Confidence values below this
# threshold will be considered a positive match because the lower
# the confidence value, or distance, the more confident the
# algorithm is that the face was correctly detected. Start with a
# value of 3000, but you might need to tweak this value down if
# you’re getting too many false positives (incorrectly recognized
# faces), or up if too many false negatives (undetected faces).
# POSITIVE_THRESHOLD = 3500.0
if RECOGNITION_ALGORITHM == 1:
elif RECOGNITION_ALGORITHM == 2:
POSITIVE_THRESHOLD = 250
else:
POSITIVE_THRESHOLD = 3000if (‘FACE_USERS’ in os.environ):
u = os.environ[‘FACE_USERS’]
users = u.split(‘,’)
print(users)
else:
# NOTE: Substitute your own user names here. These are just
# placeholders, and you will get errors if your training.xml file
# has more than 10 user classes.
users = [‘Nick’,‘User2’,‘User3’, ‘User4’,‘User5’,
‘User6’, ‘User7’, ‘User8’, ‘User9’, ‘User10’]
print(‘Remember to set the name list environment variable FACE_USERS’)Edit the values below to configure the training and usage of the
face recognition box.
if (‘FACE_ALGORITHM’ in os.environ):
set_recognition_algorithm(int(os.environ[‘FACE_ALGORITHM’]))
print(“Using FACE_ALGORITM: {0}”.format(RECOGNITION_ALGORITHM))
else:
set_recognition_algorithm(1)
print(“Using default FACE_ALGORITM: {0}”.format(RECOGNITION_ALGORITHM))File to save and load face recognizer model.
TRAINING_FILE = ‘training.xml’
TRAINING_DIR = ‘./training_data/’Size (in pixels) to resize images for training and prediction.
Don’t change this unless you also change the size of the training images.
FACE_WIDTH = 92
FACE_HEIGHT = 112Face detection cascade classifier configuration.
You don’t need to modify this unless you know what you’re doing.
See: http://docs.opencv.org/modules/objdetect/doc/cascade_classification.html
#HAAR_FACES = ‘lib/haarcascade_frontalface_alt.xml’
#HAAR_FACES = ‘lib/haarcascade_frontalface_alt2.xml’
#HAAR_FACES = ‘lib/haarcascade_frontalface_default.xml’
HAAR_FACES = ‘lib/haarcascade_frontalface.xml’
HAAR_EYES = ‘lib/haarcascade_eye.xml’
HAAR_SCALE_FACTOR = 1.05
HAAR_MIN_NEIGHBORS_FACE = 4 # 4 or 3 trainer/tester used different values.
HAAR_MIN_NEIGHBORS_EYES = 2
HAAR_MIN_SIZE_FACE = (30, 30)
HAAR_MIN_SIZE_EYES = (20, 20)def get_camera(preview=True):
try:
from . import picam
capture = picam.OpenCVCapture(preview)
capture.start()
return capture
except Exception:
from . import webcam
return webcam.OpenCVCapture(device_id=0)def is_cv2():
if CV_MAJOR_VER == 2:
return True
else:
return Falsedef is_cv3():
if CV_MAJOR_VER == 3:
return True
else:
return Falsedef model(algorithm, thresh):
# set the choosen algorithm
model = None
if is_cv3():
# OpenCV version renamed the face module
if algorithm == 1:
model = cv2.face.createLBPHFaceRecognizer(threshold=thresh)
elif algorithm == 2:
model = cv2.face.createFisherFaceRecognizer(threshold=thresh)
elif algorithm == 3:
model = cv2.face.createEigenFaceRecognizer(threshold=thresh)
else:
os._exit(1)
else:
if algorithm == 1:
model = cv2.createLBPHFaceRecognizer(threshold=thresh)
model = cv2.createFisherFaceRecognizer(threshold=thresh)
model = cv2.createEigenFaceRecognizer(threshold=thresh)
else:
os._exit(1)
return modeldef user_label(i):
“”" Generate the user lable. Lables are 1 indexed.
i = i - 1
if i < 0 or i > len(users):
return “User” + str(int(i))
return users[i]
default1 Module:
/* global Module */
/* Magic Mirror
- Module: HelloWorld
- MIT Licensed.
Module.register(“default1”,{
// Default module config.
defaults: {
text: “Hello World!”
},// Override dom generator.
getDom: function() {
var wrapper = document.createElement(“div”);
wrapper.innerHTML = this.config.text;
return wrapper;
everyone Module :
/* global Module */
/* Magic Mirror
- MIT Licensed.
Module.register(“everyone”,{
defaults: {
text: “Hello everyone!”
return wrapper;
Nick Module:
/* global Module */
/* Magic Mirror
- MIT Licensed.
Module.register(“Nick”,{
defaults: {
text: “Hello Nick!”
return wrapper;
Terminal output with config #1:
pi@MgMrPi:~ $ cd MagicMirror
pi@MgMrPi:~/MagicMirror $ npm startmagicmirror@2.1.3 start /home/pi/MagicMirror
sh run-start.shStarting MagicMirror: v2.1.3
Loading config …
Loading module helpers …
Initializing new module helper …
No helper found for module: MMM-Facial-Recognition.
No helper found for module: Nick.
All module helpers loaded.
Starting server on port 8080 …
Server started …
Starting module: newsfeed
Sockets connected & modules started …
Launching application.
Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
Create new news fetcher for url: https://news.google.com/output=rss - Interval: 300000
Create new news fetcher for url: http://rss.cnn.com/rss/cnn_topstories.rss - Interval: 300000
Create new news fetcher for url: http://news.yahoo.com/rss - Interval: 300000
Create new news fetcher for url: http://www.espn.com/espn/rss/news - Interval: 300000
Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
Whoops! There was an uncaught exception…
TypeError: parser.close is not a function
at SAXStream.openf1 (/home/pi/MagicMirror/node_modules/feedme/lib/xmlfeedparser.js:107:14)
at emitOne (events.js:96:13)
at SAXStream.emit (events.js:191:7)
at SAXParser.me._parser.(anonymous function) [as onopentag] (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:258:17)
at emit (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:624:35)
at emitNode (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:629:5)
at openTag (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:825:5)
at SAXParser.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:1391:13)
at SAXStream.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:239:18)
at module.exports.yoshi.write (/home/pi/MagicMirror/node_modules/feedme/lib/feedme.js:41:14)
If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issuesOut Come:
Calendar, current weather, Forecast, Clock, news feed and “Hello Nick!” all show up but went i put my hand over the camera “Hello Nick!” still stays visible.
Terminal output with config #2:
Loading config …
No helper found for module: everyone.
No helper found for module: default1.
Server started …
pi@MgMrPi:~/MagicMirror $Out Come:
“Hello World!” shows up at the top, “Hello Nick!” shows up in the middle and “Hello everyone!” shows up at the bottom at mirror start up. again when i put my hand of the camera all three remain visible.
Terminal output with config #3:
Loading config …
Server started …
Screen remains black nothing is shown -
@dk7988 said in Help! semester project can’t figure out facial recognition:
This error message happens when the node_helper.js file is not found for a module. The Facial-Recognition module does have one, so it appears to not be installed where the mirror expects it. Is the module checked out in the modules directory under the MagicMirror installation?
@dmcinnes
Hello, thanks for getting back to me. I’m not sure what your askingI’m unfamiliar with the whole “checked out” part but the location of the node_helper.js file is at /home/pi/MagicMirror/modules/MMM-Facial-Recognition-master/node_helper.js
Try renaming the module directory “MMM-Facial-Recognition” (without “-master”), I don’t have the code in front of me but I believe the mirror software uses the name of the module from your config as the directory name.
@dmcinnes
Oohh!! are you thinking cause the folder names is ‘MMM-Facial-Recognition-master’ and in the MagicMirror config.js file it says “module: “MMM-Facial-Recognition”,
config: { … etc” and/or in the MMM-Facial-Recognition/…/config.py file it says “Module.register(“MMM-Facial-Recognition”,
{ defaults: {…etc” and not
‘MMM-Facial-Recognition-master’? I can see how that would make since, I’ll give it a try later tonite when I get home. -
@dmcinnes
You are awesome!! thank you! that did the trick! -
Great to hear!
