    Adding Google Calendar in MMM
    18 Posts 2 Posters 26.5k Views 2 Watching
    • H Offline
      hoofta
      Re: Question about calendar
      I know I am a noob for this and I am a bit late to the party but I have followed all the steps and have yet been able to add my Google calendar to my MMM. Have there been any other changes since this thread?
      • ? Offline
        [[global:former-user]] @hoofta
        @hoofta
        For what? Exactly what do you want?
        • H Offline
          hoofta
          I am trying to add my Google calendars to show up in MMM. I see that I need to add all of my calendars individually to get my full schedule but nothing seems to work for me. All that populates is the default US Holidays. I have set my calendar to public and have gotten the appropriate ical link from Google but I’m still stuck.
          • ? Offline
            @hoofta
            Can you show us your ical url? If you don’t mind the privacy…
            Or can you make us a sample calendar url for test? We have no telesight :)
            • H Offline
              hoofta @Guest
              @Sean https://calendar.google.com/calendar/ical/hoofta%40gmail.com/public/basic.ics
              • ? Offline
                @hoofta said in Adding Google Calendar in MMM:
                Hmmm… There is no event in that calendar.
                • H Offline
                  hoofta @Guest
                  @Sean refresh. I just added two events.
                  • ? Offline
                    @hoofta
                    Well, I can see your calendar in default calendar module and MMM-CalendarExt also well. But you can’t?
                    			header: "Events",
                    						symbol: "calendar-check-o ",
                    						url: "https://calendar.google.com/calendar/ical/hoofta%40gmail.com/public/basic.ics"
                    Try this configuration.
                    • H Offline
                      hoofta @Guest
                      @Sean (due to my newbie status) this goes in the config.js or calendar.js?
                      • ? Offline
                        @hoofta
                        ok. open your config/config.js and put that codes under these;
                        			module: "alert",
                                        // here.
                        • H Offline
                          hoofta @Guest
                          @Sean :-/ it’s stuck with “Loading…”
                          • ? Offline
                            @hoofta
                            How is your internet condition? Your mirror is connected to internet?
                            • H Offline
                              hoofta @Guest
                              @Sean typically strong - fiber with at least 500gb up/down. (typing on laptop now). Internet seems very slow on r.pi running MMM. Any suggestions to boost internet speed?
                              ? 2 Replies Last reply Reply Quote 0
                              • ? Offline
                                @hoofta
                                no, just checking things clearly.
                                And let’s check more things;
                                • How’s other modules? e.g) clock, news feed, or any other third parties… Only calendar module has the problem?
                                • Default sample “US-Holiday” was shown normally?
                                • Have you tried npm run config:check? what was the result?
                                • Have you tried npm start dev ? what was the result?
                                • ? Offline
                                  I’d missed this. if so, that might be the reason. But I have no idea to speed up your internet connections.
                                  • H Offline
                                    hoofta @Guest
                                    @Sean
                                    r.pi speedtest.net returns .1 down speed
                                    I have not been able to get any other third party modules going. I have attempted the MMM-MyCommute and an iframe module for a NestCam. Neither have worked - only broke MMM.
                                    no syntax error from config:check
                                    npm start dev loaded MMM normally with dev script on the right.
                                    only possible red flag is that I see for calendar is in text/javascript there is a double “/” between calendars
                                    • H Offline
                                      hoofta @hoofta
                                      @hoofta I’ll play the newbie card on this one and admit I just found an extra “s” at the end of basic, which was causing my issue.
                                      Can I add multiple calendars to the same area so chronologically they play nicely together?
                                      • ? Offline
                                        @hoofta nice for you. It will work and ask again.
