    change font of modules (local fonts)
    Scheduled Pinned Locked Moved Solved Custom CSS
    20 Posts 7 Posters 19.8k Views 7 Watching
    • F Offline
      foryas
      hi guys,how i can change fonts of modules using custom.css and use local font?
      • brobergB Offline
        broberg Project Sponsor
        try adding add this to custom.css and your font to the fonts folder
        @font-face {
          font-family: YourFont;
          font-style: normal;
          font-weight: 100;
          src:
            local("YourFont"),
            url("fonts/Yourfont.ttf") format("truetype");
        • F Offline
          foryas @broberg
          @broberg if i want to only change font of special module not all?
          ? brobergB 2 Replies Last reply Reply Quote 0
          • ? Offline
            A Former User @foryas
            @foryas you can also do. But you need to understand css. Study it.
            1 Reply Last reply Reply Quote -2
            • brobergB Offline
              broberg Project Sponsor @foryas
              @foryas
              .calendar {
              Font-family : YourFont;
              That would change the font for the module calendar
              F 1 Reply Last reply Reply Quote 2
              • F Offline
                foryas @broberg
                @broberg said in change font of modules (local fonts):
                .calendar
                how i can find class (.calendar for your example) of any module to use that?
                • brobergB Offline
                  @foryas open the developer options in electron or check with F12 in your local browser to see the code.
                  But the main module class name are always the name of the module as put in the config file
                  .calendar for calendar
                  .alarm for alarm
                  .MMM-Instagram for MMM-Instagram
                  etc etc
                  • F Offline
                    foryas @broberg
                    @broberg so thanks my friend solved.
                      bekirs
                      hi all,
                      I tried to change my newsfeed font and i added below commands to custom.css but it didnt work. What should i do ?
                      .newsfeed {
                        font-family: Verdana;
                        font-style: normal;
                        font-weight: 100;
                        src:
                          local("Verdana"),
                          url("/home/pi/MagicMirror/fonts/Verdana.ttf") format("truetype");
                      • N Offline
                        ninjabreadman @bekirs
                        @bekirs @font-face is not a style rule, but declaration (“at-rule”). Here’s an explanation of how it works.
                        So your code should instead be:
                        @font-face {
                          font-style: normal;
                          font-weight: 100;
                          src:
                            local("Verdana"),
                        .newsfeed {
                        This avoids using the local version of the Verdana font. Why not use the local Verdana font (or install your desired alternative) and use the below instead?
                        .newsfeed {
                        Problem with config or JavaScript? Copy/paste it into JSHint.
                        Check out the detailed walkthroughs on install, config, modules, etc.
