    change font of modules (local fonts)
    Scheduled Pinned Locked Moved Solved Custom CSS
    22 Posts 9 Posters 27.2k Views 9 Watching
      bekirs
      hi all,
      I tried to change my newsfeed font and i added below commands to custom.css but it didnt work. What should i do ?
      .newsfeed {
        font-family: Verdana;
        font-style: normal;
        font-weight: 100;
        src:
          local("Verdana"),
          url("/home/pi/MagicMirror/fonts/Verdana.ttf") format("truetype");
      N 1 Reply Last reply
      • N
        ninjabreadman @bekirs
        @bekirs @font-face is not a style rule, but declaration (“at-rule”). Here’s an explanation of how it works.
        So your code should instead be:
        @font-face {
          font-style: normal;
          font-weight: 100;
          src:
            local("Verdana"),
        .newsfeed {
        This avoids using the local version of the Verdana font. Why not use the local Verdana font (or install your desired alternative) and use the below instead?
        .newsfeed {
          bekirs
          @ninjabreadman said in change font of modules (local fonts):
          @font-face {
          font-style: normal;
          font-weight: 100;
          src:
          local(“Verdana”),
          url(“/home/pi/MagicMirror/fonts/Verdana.ttf”) format(“truetype”);
          .newsfeed {
          I wrote below but it didnt work
          @font-face {
          font-style: normal;
          font-weight: 100;
          src:
          local(“Verdana”),
          .newsfeed {
          N J 2 Replies Last reply
          • N
            @bekirs My first question: Is Verdana actually located in ~/MagicMirror/fonts/Verdana.ttf? If so, you might try url("file:///home/pi/MagicMirror/fonts/Verdana.ttf"). When you run npm start dev in Terminal while in ~/MagicMirror, are there any console errors (in Terminal or Electron)?
              bekirs
              verdana is located in true folder. and after i run npm start dev i could not see any error thank you
              • N
                @bekirs Did you try using url("file:///home/pi/MagicMirror/fonts/Verdana.ttf")?
                  j.e.f.f Project Sponsor Module Developer @bekirs
                  @bekirs You need to use a virtual path to the file, not a physical path. Change your CSS as follows:
                  @font-face {
                    font-family: "Verdana";
                    font-style: normal;
                    font-weight: 100;
                    src: url("/fonts/Verdana.ttf")  format("truetype");
                  That said, I’m not sure about TrueType support in Chrome, and subsequently Electron. if this still doesn’t work, you’ll need to convert the font into a supported format, such as woff or woff2. Font Squirrel is an online tool that can do it, but you might run into copy protection issues, as Verdana is a licensed font. Do a Google search for web font generator to find other options, or you can even try searching for a woff version of Verdana.
                  Of course, the designer in me is screaming that there are so many nicer type faces suitable for UI than Verdana that are available for free. Google Fonts has many options that are readily downloadable, and subsequently can be converted to web font formats using Font Squirrel.
                  Good luck!
                  • E
                    epi
                    So, I’ve downloaded https://www.fontsquirrel.com/fonts/comic-relief and added a font to
                    And my custom css looks like this
                     body {
                    @font-face {
                      font-family: "SF";
                      font-style: normal;
                      font-weight: 100;
                      src:
                        local("ComicRelief"),
                        url("fonts/ComicRelief.ttf") format("truetype");
                    Despite that, font is not seen. What could be the reason?
                    J 1 Reply Last reply
                      j.e.f.f Project Sponsor Module Developer @epi
                      @epi don’t wrap the@font-face css rule within the body CSS rule. CSS spec says this should work but I’ve found the in most cases browsers just ignore it.
                      Reply Quote -1
                      • E
                        epi
                        Still doesn’t work
                         * Magic Mirror                                      *
                         * Custom CSS                                        *
                         * By Michael Teeuw http://michaelteeuw.nl           *
                         * MIT Licensed.                                     *
                         * Add any custom CSS below.                         *
                         * Changes to this files will be ignored by GIT. *
                        body {
                        @font-face {
                          font-family: "SF";
                          font-style: normal;
                          font-weight: 100;
                          src:
                          @epi Now you need to apply your font to various elements of the layout. All you’ve done to this point is declare the availability of the font. Try something like this:
                          body * {
                            font-family: "SF";
                          That might get the job done, but there may be more specific rules you need to write to override in other cases. Try this and see how far it gets you.
                          • E
                            epi
                            thank you!
                            D 1 Reply Last reply
                              dangerousden @epi
                              @epi
                              Did you ever get this working? I’m having exactly the same issue. I have the holiday countdown module. We’re off to Disney, so I thought it would be fun to put it in a Disney font. I’ve downloaded one and put it into a fonts folder under MagicMirror.
                              I have defined it with an @ statement, included the fonts/ source folder and file name, and added it to the countdown module, but it is still not changing the font for that module :(
                                sdetweil @dangerousden
                                @dangerousden look at the css/roboto.css, or the css/fontawesome.css
                                and then main.css to see how they are used
