    change font of modules (local fonts)
    Scheduled Pinned Locked Moved Solved Custom CSS
    22 Posts 9 Posters 27.2k Views 9 Watching
    • N
      ninjabreadman @bekirs
      @bekirs My first question: Is Verdana actually located in ~/MagicMirror/fonts/Verdana.ttf? If so, you might try url("file:///home/pi/MagicMirror/fonts/Verdana.ttf"). When you run npm start dev in Terminal while in ~/MagicMirror, are there any console errors (in Terminal or Electron)?
        bekirs
        verdana is located in true folder. and after i run npm start dev i could not see any error thank you
        N 1 Reply Last reply
        • N
          @bekirs Did you try using url("file:///home/pi/MagicMirror/fonts/Verdana.ttf")?
            j.e.f.f Project Sponsor Module Developer @bekirs
            @bekirs You need to use a virtual path to the file, not a physical path. Change your CSS as follows:
            @font-face {
              font-family: "Verdana";
              font-style: normal;
              font-weight: 100;
              src: url("/fonts/Verdana.ttf")  format("truetype");
            That said, I’m not sure about TrueType support in Chrome, and subsequently Electron. if this still doesn’t work, you’ll need to convert the font into a supported format, such as woff or woff2. Font Squirrel is an online tool that can do it, but you might run into copy protection issues, as Verdana is a licensed font. Do a Google search for web font generator to find other options, or you can even try searching for a woff version of Verdana.
            Of course, the designer in me is screaming that there are so many nicer type faces suitable for UI than Verdana that are available for free. Google Fonts has many options that are readily downloadable, and subsequently can be converted to web font formats using Font Squirrel.
            Good luck!
            • E
              epi
              So, I’ve downloaded https://www.fontsquirrel.com/fonts/comic-relief and added a font to
              And my custom css looks like this
               body {
              @font-face {
                font-family: "SF";
                font-style: normal;
                font-weight: 100;
                src:
                  local("ComicRelief"),
                  url("fonts/ComicRelief.ttf") format("truetype");
              Despite that, font is not seen. What could be the reason?
              J 1 Reply Last reply
                j.e.f.f Project Sponsor Module Developer @epi
                @epi don’t wrap the@font-face css rule within the body CSS rule. CSS spec says this should work but I’ve found the in most cases browsers just ignore it.
                Reply Quote -1
                • E
                  epi
                  Still doesn’t work
                   * Magic Mirror                                      *
                   * Custom CSS                                        *
                   * By Michael Teeuw http://michaelteeuw.nl           *
                   * MIT Licensed.                                     *
                   * Add any custom CSS below.                         *
                   * Changes to this files will be ignored by GIT. *
                  body {
                  @font-face {
                    font-family: "SF";
                    font-style: normal;
                    font-weight: 100;
                    src:
                    @epi Now you need to apply your font to various elements of the layout. All you’ve done to this point is declare the availability of the font. Try something like this:
                    body * {
                      font-family: "SF";
                    That might get the job done, but there may be more specific rules you need to write to override in other cases. Try this and see how far it gets you.
                    • E
                      epi
                      thank you!
                      D 1 Reply Last reply
                        dangerousden @epi
                        @epi
                        Did you ever get this working? I’m having exactly the same issue. I have the holiday countdown module. We’re off to Disney, so I thought it would be fun to put it in a Disney font. I’ve downloaded one and put it into a fonts folder under MagicMirror.
                        I have defined it with an @ statement, included the fonts/ source folder and file name, and added it to the countdown module, but it is still not changing the font for that module :(
                          sdetweil @dangerousden
                          @dangerousden look at the css/roboto.css, or the css/fontawesome.css
                          and then main.css to see how they are used
