    MMM-stib does not display, but data is on the start screen.
    Scheduled Pinned Locked Moved Unsolved Transport
    1 Posts 1 Posters 980 Views 1 Watching
    • L Offline
      lucberger
      Re: STIB Brussels Transport Waiting time at stops
      MMM-stib does not display, but data is on the terminal screen: I start MM from a terminal and it display correctly the modules, but without stib data. Howerver, after aborting, the terminal show this, with block “STIB this.lines” repeated many times :
      Please tell if another info is necessary to document my problem !
      What am I missing ?
      pi@raspberrypi3:~/MagicMirror $ npm start
      magicmirror@2.1.3 start /home/pi/MagicMirror
      sh run-start.sh
      Starting MagicMirror: v2.1.3
      Loading config …
      Loading module helpers …
      Initializing new module helper …
      Module helper loaded: stib
      All module helpers loaded.
      Starting server on port 8080 …
      Server started …
      Starting module: newsfeed
      Connecting socket for: stib
      Starting node helper for: stib
      Sockets connected & modules started …
      Launching application.
      Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
      Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
      Create new waiting time fetcher for url: http://m.stib.be/api/getwaitingtimes.php?halt=5802 - Interval: 60000
      Create new waiting time fetcher for url: http://m.stib.be/api/getwaitingtimes.php?halt=5714 - Interval: 60000
      STIB this.lines {“stopname”:[“TILLEUL”],“position”:[{“latitude”:[“50.87593”],“longitude”:[“4.39285”]}],“waitingtime”:[{“line”:[“55”],“mode”:[“T”],“minutes”:[“1”],“destination”:[“ROGIER”],“message”:[“”]},{“line”:[“55”],“mode”:[“T”],“minutes”:[“5”],“destination”:[“ROGIER”],“message”:[“”]}]}
      STIB node helper {“stopname”:[“TILLEUL”],“position”:[{“latitude”:[“50.87593”],“longitude”:[“4.39285”]}],“waitingtime”:[{“line”:[“55”],“mode”:[“T”],“minutes”:[“1”],“destination”:[“ROGIER”],“message”:[“”]},{“line”:[“55”],“mode”:[“T”],“minutes”:[“5”],“destination”:[“ROGIER”],“message”:[“”]}]}
      EDIT:
      After a good night and some search, if found this site [https://forum.magicmirror.builders/topic/151/stib-brussels-transport-waiting-time-at-stops/3](link url)
      and it solve my problem.
      Thanks for reading !
