    • Search
    MagicMirror² v2.24.0 is available! For more information about this release, check out this topic.
    Quit MM with script
    Troubleshooting
      start-the-fire last edited by
      I’m kinda fresh to the python & bash programming but I make some progress.
      I set up my MM with additional modules and an Alexa Skill via AWS services which works quite well (atm turn HDMI port on/off + start MM via npm start trigger)
      This works all without any problems at the moment. I set up today the MM launch via pm2 which launches the application after every reboot. Right know I’m looking for any script (bash / python, …?) with whom I could stop the MM instance (going on I would like to activate this via an Alexa Skill trigger)
      //#taken from www.cyber-omelette.com/2017/01/alexa-run-script.html
      print(message)
                      if message == "on":
                              os.system("~/on.sh")
                      elif message == "off":
                              os.system("~/off.sh")
      		elif message == "start":
      			os.system("~/mm.sh")
      I tried some things I came up with but I’m kind clueless how I could do this 😕
      So I’m looking for two options to quit MM - CTRL-C isn’t an option cause I’m using my rpi without any keyboard that’s why I try to set up everything with Alexa voice commands:
      • -> Script for deactivating MM which has been started by pm2*
      • -> Script for deactivation MM which hast been started manual*
      //#taken from MM tutorial
      //#used for pm2 & manual start with Alexa skill (if needed)
      /cd ~/MagicMirror
      DISPLAY=:0 npm start
      If anyone have some recommendations & hints for me I would be more than pleased
      Cheers Ben
      • Mr.Sponti
        Mr.Sponti last edited by
        @start-the-fire said in Quit MM with script:
        Hi, maybe you can use my bash script mmhelper.sh to start/stop MagicMirror from the command line or from another script (e.q. python, nodejs).
        #!/bin/bash
        #	mmhelper.sh  start | stop | status | hdmi_on | hdmi_off| hdmi_status
        #   Last edited:    10.09.2017          (c) Mr.Sponti
        #set -x
        HOME=/home/pi
        PATH=$PATH:$PWD
        MY_NAME=$(basename -- "$0")
        function monitor_on() {
            /opt/vc/bin/tvservice --preferred > /dev/null 2>&1
            sudo chvt 6
            sudo chvt 7
        function monitor_off() {
            /opt/vc/bin/tvservice --off > /dev/null 2>&1
        function monitor_status() {
            #  get power status --> 1 = off ,  0 = on
            power=$(/opt/vc/bin/tvservice --status |grep "TV is off"|wc -l)
            if [ $power -eq 1 ]
            then
                echo "off"
            elif [ $power -eq 0 ]
            then
                echo "on"
            fi
        # check first runstring parameter
        if [ -z "$1" ]
        then
        	cmd=start
        else
        	cmd=$1
        fi
        case $cmd in
            "start") #  start MagicMirror
                pm2 start mm
            "stop") #  stop MagicMirror
                pm2 stop all
            "status")
                pm2 status mm
            "hdmi_on") #  switch monitor on
                monitor_on
                monitor_status
            "hdmi_off") # switch monitor off
                monitor_off
                monitor_status
            "hdmi_status")
                monitor_status
            *) echo "undefined command"
               echo "usage: $MY_NAME start|stop|status|hdmi_on|hdmi_off|hdmi_status"
        esac
        You also need the mm.sh script in your home directory!
        pm2 flush
        # start Magic Mirror system
        cd ~/MagicMirror
        Merry Christmas!
