    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 527.1k Views 48 Watching
      sdetweil
      wrong folder… in MagicMirror always for start. not module folder
        rakostamas @sdetweil
        1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start', 'dev' ]
        2 info using npm@6.6.0
        3 info using node@v9.11.2
        4 verbose stack Error: missing script: start
        4 verbose stack     at run (/usr/lib/node_modules/npm/lib/run-script.js:155:19)
        4 verbose stack     at /usr/lib/node_modules/npm/lib/run-script.js:63:5
        4 verbose stack     at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:115:5
        4 verbose stack     at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:418:5
        4 verbose stack     at checkBinReferences_ (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:373:45)
        4 verbose stack     at final (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:416:3)
        4 verbose stack     at then (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:160:5)
        4 verbose stack     at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:364:12
        4 verbose stack     at /usr/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:90:16
        4 verbose stack     at FSReqWrap.readFileAfterClose [as oncomplete] (fs.js:525:3)
        5 verbose cwd /home/pi/MagicMirror/modules/MMM-Fuel
        6 verbose Linux 4.14.79-v7+
        7 verbose argv "/usr/bin/node" "/usr/bin/npm" "start" "dev"
        8 verbose node v9.11.2
        9 verbose npm  v6.6.0
        10 error missing script: start
        11 verbose exit [ 1, true ]
        S strawberry 3.141S 2 Replies Last reply Reply Quote 0
          sdetweil @rakostamas
          @rakostamas said in MMM-Fuel:
          please do
          cd ~/MagicMirror
          then
          npm start dev
            rakostamas
            Yes I got errors.
            GET http://localhost:8080/modules/MMM-Fuel//MMM-Fuel.js net : : ERR_CACHE_READ_FAILURE
            Error on loading script: modules/MMM-Fuel//MMM-Fuel.js
              sdetweil
              sorry, I do not know why reading from the local disk would fail with cache read failure error
              • strawberry 3.141S Offline
                strawberry 3.141 Project Sponsor Module Developer @rakostamas
                @rakostamas as @sdetweil already mentioned you need to start the mirror not the module.
                cd ~/MagicMirror && npm start dev
                  rakostamas @strawberry 3.141
                  @strawberry-3-141
                  yes, I have opened it, and I got the errors what I wrote in my last comment
                    @rakostamas did you check that the file exists? Maybe something went wrong during the cloning of the module
                    • V Offline
                      VanDerPol
                      hello
                      I have the same problem like rakostamas.
                      As headline there stands Spritpreise und below there stands loading.
                      I am from Austria and I use provider Spritpreisrechner.
                      Unfortunately I can’t find the mistake. Could you please help me?
                      Sorry My english is not the yellow from the egg :)
                      My Config:
                                           module: "MMM-Fuel",
                                                   lat: 48.527710,
                                                   lng: 16.361530,
                                                   radius: 15,
                                                   max: 5,
                                                   map_api_key: false,
                                                   zoom: 12,
                                                   width: 600,
                                                   height: 600,
                                                   colored: true,
                                                   open: false,
                                                   shortenText: false,
                                                   showAddress: true,
                                                   showOpenOnly: false,
                                                   iconHeader: true,
                                                   rotate: true,
                                                   types: ['diesel'],
                                                   sortBy: 'diesel',
                                                   rotateInterval: 60 * 1000, // every minute
                                                   updateInterval: 15 * 60 * 1000, // every 15 minutes
                                                   provider: 'spritpreisrechner',
                                                   toFixed: false
                        I just merged a new version of this module into master.
                        New: Support for gas stations in new south wales australia
                        Changed: I rewrote most of the module, make sure you also install the dependencies after the update.
                        [card:fewieden/MMM-Fuel]
                        • 10
                        • 11
                        • 12
                        • 13
                        • 14
                        • 17
                        • 18
                        • 12 / 18
