    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 527.1k Views 48 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer @Stefan_TR96
      @Stefan_TR96 Data could have changed.
        sdetweil @Stefan_TR96
        @Stefan_TR96 did u run npm install in the module folders with a package.json file? u need to
          Stefan_TR96 @sdetweil
          @sdetweil said in MMM-Fuel:
          tried to install it again and got following warning:
          npm WARN stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none is installed. You must install peer dependencies yourself.
            @Stefan_TR96 that’s just a warning
              Stefan_TR96
              @cowboysdude if I type the generated url manually to the browser, I get the data
                @Stefan_TR96 >tried to install it again and got following warning:
                what is ‘it’…
                the module may need updating after MM was updated…
                do
                cd ~/MagicMirror/modules/MMM-Fuel
                npm install
                  Stefan_TR96
                  @sdetweil i did de install again (changed to MM-Fuel directory and did sudo npm install) as you wrote and got the warning i posted
                    @Stefan_TR96 said in MMM-Fuel:
                    sudo
                    never sudo
                      Stefan_TR96
                      @sdetweil same results without sudo
                        @Stefan_TR96 yes, does mm run? Do you get output?
                        • 12
                        • 13
                        • 14
                        • 15
                        • 16
                        • 17
                        • 18
                        • 14 / 18
