    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 527.0k Views 48 Watching
    • C Offline
      codac
      With the new update of MM I’m getting the following error:
      0|mm       | [15.04.2021 14:11.21.945] [ERROR] (node:15096) UnhandledPromiseRejectionWarning: Error: Cannot find module 'geolib'
      0|mm       | Require stack:
      0|mm       | - /home/pi/MagicMirror/modules/MMM-Fuel/apis/tankerkoenig.js
      0|mm       | - /home/pi/MagicMirror/modules/MMM-Fuel/node_helper.js
      0|mm       | - /home/pi/MagicMirror/js/app.js
      0|mm       | - /home/pi/MagicMirror/js/electron.js
      0|mm       | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
      • C Offline
        Commander @strawberry 3.141
        @strawberry-3-141
        Hello, i want to check prices of only 3 specific gas stations, but it doesn`t work.
        code_text:
                       api_key: "XXXXXXXXXXXXX-XXX-XXXX-XXXXXXXXXXXX",
                       types: ["e5"],
               	       rotate: true,
               	       showDistance:false,
               	       lat: 50.8634,
                       lng: 8.03944,
                       stationIds: ["238715f9-60d6-4f7a-9e74-c40fdb71a79d"],
                       radius: 0,
               	       lat: 50.8708534,
                       lng: 8.014519,
                       stationIds: ["1b41801e-ee5e-490e-86d6-474bafec5dc4"],
                       radius: 0,
               	       lat: 50.871715,
               	       lng: 8.012415,
                       stationIds: ["4b9763df-8cce-426f-a1d5-2b44d413550a"],
                       radius: 0,
                       // all your config options, which are different than their default values
        I try to set stationIds like that:
        stationIds: ["238715f9-60d6-4f7a-9e74-c40fdb71a79d,1b41801e-ee5e-490e-86d6-474bafec5dc4,4b9763df-8cce-426f-a1d5-2b44d413550a"],
        but it also doesn`t work.
        Could you explaine how set specific gas stations?
        JalibuJ 1 Reply Last reply Reply Quote 0
        • JalibuJ Offline
          Jalibu Module Developer @Commander
          @commander said in MMM-Fuel:
          stationIds: [“238715f9-60d6-4f7a-9e74-c40fdb71a79d,1b41801e-ee5e-490e-86d6-474bafec5dc4,4b9763df-8cce-426f-a1d5-2b44d413550a”],
          try
          stationIds: ["238715f9-60d6-4f7a-9e74-c40fdb71a79d", "1b41801e-ee5e-490e-86d6-474bafec5dc4", "4b9763df-8cce-426f-a1d5-2b44d413550a"],
          C 1 Reply Last reply Reply Quote 1
          • C Offline
            Commander @Jalibu
            @jalibu said in MMM-Fuel:
            stationIds: [“238715f9-60d6-4f7a-9e74-c40fdb71a79d”, “1b41801e-ee5e-490e-86d6-474bafec5dc4”, “4b9763df-8cce-426f-a1d5-2b44d413550a”],
            Oh yes tanks !
              Seansation
              Hello,
              is it possible to sort by distance without rotation?
              			module: "MMM-Fuel",
              				api_key: "my_key",
              				showAddress: false,
              				rotate: false,
              				lat: my_lat,
              				lng: my_lng,
              				shortenText: false,
              				types: ["e5"],
              				sortBy: "e5", //possible to sort by distance? e.g. sortBy: "distance"
              Thank you
              • strawberry 3.141S Offline
                strawberry 3.141 Project Sponsor Module Developer @Seansation
                @seansation this is currently not supported, feel free to send a pr.
                  Now also supporting fuel prices in the USA. Take a look at https://github.com/cowboysdude/MMM-Gas for different style of the same information.
                  2.3.0
                  MagicMirror² version >= 2.15.0 required.
                  Added
                  • Provider: autoblog
                  • Config option: showBrand
                  • Integrated MagicMirror logger on server side
                  • Dependency: node-html-parser
                  • Config option excludeStationIds to exclude gas stations from radius (Tankerkönig only)
                  Changed
                  • Updated Github config files
                  • Updated dependencies
                  Removed
                  • Dependency: fs-extra
                  • Dependency: geolib
                  Link to module https://github.com/fewieden/MMM-Fuel
                  cowboysdudeC 1 Reply Last reply Reply Quote 2
                    Fixed
                    • Tankerkoenig prices for requests with stationIds
                    • JerryPJ Offline
                      JerryP
                      Is this also running for the Dutch petrol prices???
                        Ray
                        This is a great app. Good job well done
                        is there a way to add a favorite gas station
                        or make it a future project
                        I’m in the United States so I’m using that configuration
                        • 14
                        • 15
                        • 16
                        • 17
                        • 18
                        • 17 / 18
