    Need help with config syntax error
    5 Posts 2 Posters 3.2k Views 2 Watching
      beck0r
      Hey there,
      i had to turn off my pi for a while since I’ve moved to a new location. During the starting sequence of MM it tells me I have syntax errors in my config. I can’t really imagine since I haven’t touched the config at all. JS syntax checkers keep telling me that the config is correct but my screen stays black.
      Can somebody help me? It’s been a while since I have faced the syntax of the config file so I’m not familiar with it any longer.
      Thank you very much
      Starting MagicMirror: v2.1.1
      Loading config ...
      Loading module helpers ...
      Module helper loaded: MMM-Admin-Interface
      Module helper loaded: MMM-voice
      Module helper loaded: MMM-DHT22
      WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
      App threw an error during load
      SyntaxError: Error parsing /home/pi/MagicMirror/modules/MMM-History/node_modules/request/package.json: Unexpected token  in JSON at position 4111
          at JSON.parse ()
          at readPackage (module.js:92:52)
          at tryPackage (module.js:102:13)
          at Function.Module._findPath (module.js:183:20)
          at Module._resolveFilename (module.js:468:25)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
          at Function.Module._load (module.js:418:25)
          at Module.require (module.js:498:17)
          at require (internal/module.js:20:19)
          at Object. (/home/pi/MagicMirror/modules/MMM-History/node_helper.js:8:17)
      { SyntaxError: Error parsing /home/pi/MagicMirror/modules/MMM-History/node_modules/request/package.json: Unexpected token  in JSON at position 4111
          at JSON.parse ()
        path: '/home/pi/MagicMirror/modules/MMM-History/node_modules/request/package.json' }
      Launching application.
      Config removed. yawns
      • Y Offline
        yawns Moderator
                						destination: '###',,
                						label: 'Fahrrad zur Arbeit',
        There is an additional comma which needs to be removed after destination.
        I removed your config from your post as it included apikeys which should not be disclosed
          beck0r
          Hey,
          thank you for your answer. About the additional comma. This happened when I replaced my personal information with ###. I have now removed the api keys. Thanks for taking care!
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var config = {
          	port: 8080,
          	ipWhitelist: ["###"], // Set [] to allow all IP addresses.
          	language: "de",
          	timeFormat: 24,
          	units: "metric",
          			//module: "alert"
          			module: "updatenotification",
          			position: "top_bar"
              			module: "MMM-Admin-Interface"
             			module: 'MMM-voice',
              			position: 'top_left',
                 				 microphone: 1,
                 				 keyword: 'MAGIC',
          				 timeout: 15
          			module: "clock",
          				showWeek: true
          			header: "Deine Termine",
          						symbol: "calendar-check-o ",
          						url: "###"
          			module: "compliments",
          			position: "lower_third",
          			updateInterval: 20000,
          				remoteFile: "custom_complis.json"
          			module: "currentweather",
          			header: "Aktuelles Wetter",
          				locationID: "2937591",  //ID from http://www.openweathermap.org/help/city_list.txt
          				appid: "###",
          				appendLocationNameToHeader: true,
          				degreeLabel: true,
          				showHumidity: true
          			module: "weatherforecast",
          			header: "Wettervorhersage",
          				appid: "###",
          				colored: true,
          				showRainAmount: true
             			module: "MMM-DHT22",
          			header: "Raumtemperatur",
                  			sensorPIN: 3,
                  			updateInterval: 1 // Minutes
          			module: "newsfeed",
          			position: "bottom_bar",
          				feeds: [
          						title: "kicker.de",
          						url: "http://rss.kicker.de/news/fussball"
          						title: "spiegel.de",
          						url: "http://www.spiegel.de/schlagzeilen/tops/index.rss"
          				showSourceTitle: true,
          				showPublishDate: true,
          				showDescription: true,
          				wrapDescription: false
          				//module: 'MMM-History',
          				//position: 'top_right',
                    		//config: {
          					//maxWidth: "300px"  // Increase to maximum px or 100% to stretch across mirror. See Examples above.
          			module: "MMM-SystemStats",
          			position: "top_right", // This can be any of the regions.
          			header: "System Stats", // This is optional
          			classes: "small dimmed", // Add your own styling. Optional.
          				updateInterval: 10000,
          				animationSpeed: 0,
          				align: 'right' // align labels
              			module: 'MMM-ip',
          			config:  {
          				 fontSize: 16,
          				 showFamily: "IPv4",
          				 voice: false
            				module: 'MMM-MyCommute',
              					showHeader: true,
              					headerText: 'Verkehr',
             					apikey: '###',
              					origin: '###',
              					startTime: '05:00',
              					endTime: '20:00',
              					destinations: [
                  						destination: '###',
                 	 						label: 'Auto zur Arbeit',
                  						mode: 'driving',
                  						color: '#7D26CD'
                  						destination: '###',
                  						mode: 'bicycling',
          							color: '#FFB444'
                  						destination: '###',
                  						label: 'RMV zur Arbeit',
                  						mode: 'transit',
          							color: '#FF73D5'
          			module: 'MMM-Globe',
          			position: 'top_center',
          				style: 'europeDiscNat',
          				imageSize: 300,
          				updateInterval: 10*60*1000
          			module: 'MMM-SoccerLiveScore',
          			header: 'Live-Scores',
          				leagues: [35, 1, 9],
                  			showNames: true,
                  			showLogos: true,
                  			displayTime: 60 * 1000,
                  			showTables: true
          			module: 'MMM-Podcast',
          				feedUrl: 'http://www.tagesschau.de/export/video-podcast/webxl/tagesschau-in-100-sekunden/'
          		module : 'MMM-RandomBackground',
          		position : 'fullscreen_below', // Any region but this one makes the most sense
          		config : {
          			animationSpeed : 4000,
          			updateInterval : 9000
                     	 	module: 'MMM-Carousel',
                          		transitionInterval: 10000,
                          		ignoreModules: ['MMM-DHT22'],
                          		mode: 'positional',
                          		bottom_right: {enabled: true, ignoreModules: [], overrideTransitionInterval: 10000},
          • Y Offline
            yawns Moderator @beck0r
            @beck0r
            And still, without the additional comma, your magicmirror rejects the config?
              beck0r
              Yes… I am trying to uncomment the MMM-History area. With that area not included MM starts (still throwing errors messages but it works). Akismet won’t let me change my post :)
