    Blank screen - noob needs support
    4 Posts 2 Posters 3.0k Views 2 Watching
    • C
      chris1971
      Hi, I just finished my MM project and it works fine for 5 days. This morning I got a blank screen with following notification:
      Starting MagicMirror: v2.1.3
      Loading config ...
      Loading module helpers ...
      No helper found for module: MMM-TextClock.
      No helper found for module: MMM-Globe.
      No helper found for module: MMM-GoogleMapsTraffic.
      All module helpers loaded.
      Server started ...
      Starting module: newsfeed
      { Error: listen EADDRINUSE 127.0.0.1:8080
          at Object.exports._errnoException (util.js:1050:11)
          at exports._exceptionWithHostPort (util.js:1073:20)
          at Server.setupListenHandle [as _listen2] (net.js:1263:14)
          at listenInCluster (net.js:1304:12)
          at doListen (net.js:1428:7)
          at GetAddrInfoReqWrap.asyncCallback [as callback] (dns.js:62:16)
          at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:78:10)
        code: 'EADDRINUSE',
        errno: 'EADDRINUSE',
        syscall: 'listen',
        address: '127.0.0.1',
        port: 8080 }
      Any ideas?
      Thx and Regards, Chris
      • C
        chris1971
        Problem solved - I installed an other SD Card with the backup of MM and everything is working fine again… but I do not know what happened before. So I will have a backup in the desk if something will appear in near future ;-)
        Regards, Chris
        strawberry 3.141S 1 Reply Last reply
        • strawberry 3.141S
          strawberry 3.141 Project Sponsor Module Developer @chris1971
          @chris1971 something was already using port 8080, probably the previous instance of magic mirror was not shut down properly and still occupying this port, or a different programm was using it
          Reply Quote 1
          • C
            chris1971
            I have powered the PI and monitor via a wlan socket which can be switched on/off - could this cause the problem?
            Regards, Chris
