Blank screen - noob needs support
4 Posts 2 Posters 2.3k Views 2 Watching
    chris1971
    Hi, I just finished my MM project and it works fine for 5 days. This morning I got a blank screen with following notification:
    Starting MagicMirror: v2.1.3
    Loading config ...
    Loading module helpers ...
    No helper found for module: MMM-TextClock.
    No helper found for module: MMM-Globe.
    No helper found for module: MMM-GoogleMapsTraffic.
    All module helpers loaded.
    Server started ...
    Starting module: newsfeed
    { Error: listen EADDRINUSE 127.0.0.1:8080
        at Object.exports._errnoException (util.js:1050:11)
        at exports._exceptionWithHostPort (util.js:1073:20)
        at Server.setupListenHandle [as _listen2] (net.js:1263:14)
        at listenInCluster (net.js:1304:12)
        at doListen (net.js:1428:7)
        at GetAddrInfoReqWrap.asyncCallback [as callback] (dns.js:62:16)
        at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:78:10)
      code: 'EADDRINUSE',
      errno: 'EADDRINUSE',
      syscall: 'listen',
      address: '127.0.0.1',
      port: 8080 }
    Any ideas?
    Thx and Regards, Chris
      chris1971
      Problem solved - I installed an other SD Card with the backup of MM and everything is working fine again… but I do not know what happened before. So I will have a backup in the desk if something will appear in near future ;-)
      Regards, Chris
      S 1 Reply Last reply Jan 7, 2018, 2:11 PM Reply Quote 0
        strawberry 3.141 Project Sponsor Module Developer @chris1971
        @chris1971 something was already using port 8080, probably the previous instance of magic mirror was not shut down properly and still occupying this port, or a different programm was using it
          chris1971
          I have powered the PI and monitor via a wlan socket which can be switched on/off - could this cause the problem?
          Regards, Chris
