    MMM-page-indicator: No marked indicator when changing pages with remote control
    mmm-pagesmmm-page-indicatorremote control
    3 Posts 2 Posters 2.6k Views 2 Watching
    • MrCoffeeM
      MrCoffee
      Hi everone,
      I am using the remote control modul to control my mirror.
      Everything works fine except one little thing. I use the MMM-pages and MMM-page-idicator modules.
      On mirror start-up I can see the two page indicators: a white one for the opened page and a black one for the other “closed” page. The two icons are as default.
      I change the pages using the command: http://ip:8080/remote?action=NOTIFICATION& notification=PAGE_CHANGED&payload=%221%22. It works fine but however the two page indicators turn to black. So I can´t see the selected page anymore.
      Do you have an idea?
      Thanks a lot.
      Mr.Coffee
      • T
        TheChrisDees
        Hi there!
        Did you ever get a solution to your issue? I’m curious as to how you set up your remote control to send notifications to change your pages because I am actually trying to do the same thing. I’m very new to RPi and MM so I’m learning as I go.
        I have both Pages and Remote Control (RC) installed and now I’m trying to create a button on the RC website that I access from my iPhone so that when pressed will load the desired page. Any push in the right direction would be appreciated.
        Thanks!
        • MrCoffeeM
          MrCoffee
          yes, I have found a solution. The developer helped me out.
          It is very simple. Just keep the “” away from the page number. (Somehow it is %22 in my post above.)
          Just open a browser and enter
          http://ip:8080/remote?action=NOTIFICATION& notification=PAGE_CHANGED&payload=1
          Please remove the space between NOTIFICATION& and notification. The text is written wrong if I put it together.
          0 is page one. 1 page two and so on.
          As an alternative you can try
          http://ip:8080/remote?action=NOTIFICATION& notification=PAGE_DECREMENT
          or PAGE_INCREMENT
          I use these commands to control the mirror using my smart home gesture control.
          Thats why I had no need to modify the remote control module.
          Hope it helps you anyway.
          In my case, it works like a charm.
